wastegate pulling vacuum?
Old Oct 22, 2002 | 08:06 PM
boostaholic's Avatar
Default wastegate pulling vacuum?
I noticed today that the top port of my wastegate was pulling vacuum. We broke my throttle body gasket while changing out the TPS sensors and had low vacuum at idle (~10 inches Hg) so i assumed that's where the problem was. Changed the gasket today and it was still low, so i traced it back to the top port on the wastegate. I have it setup to run off the wastegate, so the top port is vented to the atmosphere and the side port is tapped to the intake manifold. At idle when i plug the top port, vacuum goes back to a normal 20 inches Hg. For reference i'm using a Tial 40mm wastegate. Car runs fine, wastegate holds boost where i have it set, and we dynoed it exactly like this. So it's not big a problem, just can't figure out why it started doing this.
Old Oct 22, 2002 | 08:24 PM
racerxadam's Avatar
Default Re: wastegate pulling vacuum? (boostaholic)
maybe there is a small rip in the diaphragm
EJ1 wilcox
Jun 15, 2005 06:52 AM
vet_girl
Jan 15, 2004 04:36 PM
88crxvtec
Jun 21, 2003 08:40 PM
boosted hybrid
Oct 16, 2002 09:49 PM
PureTeg420
Dec 24, 2001 02:27 PM
