Wastegate Problems? hard choke.
Old Oct 2, 2011 | 12:24 PM
My_EFsedan's Avatar
Default Wastegate Problems? hard choke.
my cousin sold one of my friends a d16z6 motor and a turbo kit.
d16z6 30000miles
-ebay cast manifold
-ebay waste gate
-ebay greddy bov rep
-ebay ic/fmic
-garrett 50trim .63hot
-sp dp and dt
-550 or 750cc injectors dont remember.
added blox cam, springs, retainers and aem cam gears. tuned @ 8 psi making 210hp up to 7200 rpm. car drove fine and dyno'd fine.
now when driving, 1st goes up the rpm fine, then 2nd and the rest of the gears, when ever hitting 5800rpm, the car has a huge choke like the feeling of downshifting without hitting the gas. but drops boost completely like the wastegate had taken a dump (lol) during getting on the gas.
he thinks its the wastegate and i do too. so he will be getting a tial gate tonight but wanted to know if that would solve the problem (will be getting it anyways to replace the knock off gate)
i should of recorded this haha.
Old Oct 2, 2011 | 12:38 PM
1KWHP1G's Avatar
Default Re: Wastegate Problems? hard choke.
Make sure you don't have any boost leaks. It sounds like text book fuel-cut. But I can't tell for sure without either seing it in person or atleast seeig a video of what it's doing. Does it What happens when you free rev it out of gear. Check your vacc lines. Also,if you had the batt disconnected and you run a programmable piggy back make sure values are still the same.
Old Oct 2, 2011 | 12:55 PM
My_EFsedan's Avatar
no boost leak. has the valve seat in it. the boost gauge doesnt spike during boost as far as i driven it. feels different/harder than a fuel cut. when you free rev it, its fine. vacuum lines are zip tied all in its stock locations.
could you explain that last sentence for me? i didnt quiet understand that.
Old Oct 2, 2011 | 09:40 PM
92frostwhtdb2's Avatar
He means if it was tuned on some sort of piggyback such as "afc neo" for example,the programmed values didn't reset..which is possible, but prolly unlikely since they have an internal backup battery.
I personally don't think its the wastegate though.
You gotta make sure those two other variables (fuel & spark) aren't preventing you from making that boost.
What sort of engine management is it tuned on?Is it a stock map sensor?(yes I kno stock is good to around 10psi but still)
Old Oct 2, 2011 | 09:46 PM
My_EFsedan's Avatar
tuned on crome p28
Old Oct 17, 2011 | 08:42 PM
My_EFsedan's Avatar
changed to the tial gate and still does this "choke"
Old Oct 18, 2011 | 06:34 AM
TheShodan's Avatar
Moderator
We need a video of this, sir. There's no way to tell based upon your description.
Old Oct 18, 2011 | 09:44 AM
My_EFsedan's Avatar
friends coming over at 1pm i will make a video of it.
Old Oct 18, 2011 | 10:35 AM
viper_boy403's Avatar
What are your spark plug gaps set at? Sounds like boost cut or spark blowout
Old Oct 18, 2011 | 11:34 AM
My_EFsedan's Avatar
i'd have to ask him. the tuner sold him 1 step colder plugs and gapped it.
Old Oct 18, 2011 | 11:53 AM
Hidenplanvew's Avatar
what kind of tune?
Old Oct 18, 2011 | 12:05 PM
My_EFsedan's Avatar
i dont know what the dyno is called. its in the ground and tuned for like 2 hours @ 8psi. was fine on the dyno.
Old Oct 18, 2011 | 02:46 PM
TurboFocus's Avatar
See if the turbo is hitting the compressor cover causing it to stop spinning.
Old Oct 18, 2011 | 03:07 PM
My_EFsedan's Avatar
is that possible? would it chipped all off and hear noises? 1st gear goes through just fine.
Old Oct 18, 2011 | 11:59 PM
My_EFsedan's Avatar
problem starts :36 sec. its not flucuating idle either. hes just getting use to the stage 4 clutch by pre-revving.
http://www.youtube.com/watch?v=y5xPv...el_video_title
Old Oct 19, 2011 | 03:26 AM
wolve's Avatar
x2
Old Oct 19, 2011 | 11:51 PM
My_EFsedan's Avatar
its at .026 on all four when i checked today..
Old Oct 20, 2011 | 03:11 AM
wolve's Avatar
gap is pretty tight.
sounds like boost cut to me then. if boost cut is set to sharp it can cause these problems
had this happen to me on a holset gsr i tuned, never came close to the boost cut on the gauge/datalog but still activated it, raised it a bit and it went away
Old Oct 20, 2011 | 08:08 AM
do you have a boost controller? With mine it would spike for a second and hit boost cut if I mashed the throttle too quickly instead of rolling into it (small turbo, fast spool) 8psi shouldnt spike to boost cut though unless the tuner set it really low...
Old Oct 20, 2011 | 08:49 AM
Gunmetal_B20_Hatch's Avatar
x2
I cant hear the video at work, buuuut from the description, it sounded to me like boost-cut in the beginning... undo the boost controller(if youve got one) and make a run. There is more load on the road than on a dyno(without a load cell). Ask your tuner to raise your boost-cut 2psi
Old Oct 20, 2011 | 10:35 AM
My_EFsedan's Avatar
kinda sound stupid, cant someone explain boost cut? (what i meant in boost cut was like boosting to 8 and drops over and over) what do you mean by setting it really low??
it had a XS controller and now has a blox boost controller. 1st gear goes through the rpm fine, 2nd-5th goes to about 5k then it starts to jerk back and forth. the tuner is far from us actually.
Old Oct 20, 2011 | 11:23 AM
My_EFsedan's Avatar
ok, called then tuner and the boost cut is @ 9.5 psi.
Old Oct 20, 2011 | 11:47 AM
remove the boost controller and see if the problem goes away. What psi spring do you have in the wastegate?
Old Oct 20, 2011 | 01:40 PM
My_EFsedan's Avatar
its like a 7. something i dont remember
Old Oct 20, 2011 | 02:15 PM
turbohatch96y7's Avatar
I vote boost cut too what kind of gauge do u have. Its prolly creeping in every gear but fiirst since there's more of a load on the engine. Set ur boost to about 5 psi and see if it still cuts out..
