wastegate open at idle
hey guys, i have a 44mm tial on a fullrace manifold. i have a screamer pipe. there is exhaust gas coming out at idle, i took the wastegate off, the" piston " inside the tial, the diameter is smaller than the casting hole in the main body of the tial wastedgate, so gases are just floing past it,
or is it just me and they come like this?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by twkdCD595 »</TD></TR><TR><TD CLASS="quote">you need the valve seat/ seal ring that goes in the bottom of the wastegate.
looks like this.
looks like this.
i dont think i got anything like that wen i bought it, just a v band flange which we made the screamer pipe from? mmmmmm very strange should that not have been fitted in there alreay?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hyabusa hunter »</TD></TR><TR><TD CLASS="quote">no, i mean a have a v band flange to weld my screamer pipe.
I think you weld the firing ring and made your dumptube. Either way it sounds like you need a firing ring.
</TD></TR></TABLE>I think you weld the firing ring and made your dumptube. Either way it sounds like you need a firing ring.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Fitti »</TD></TR><TR><TD CLASS="quote">
I think you weld the firing ring and made your dumptube. Either way it sounds like you need a firing ring. </TD></TR></TABLE>
i dont think so, cause if the firing ring was the same size as the v band flange, the thing would never mount up? true? it seems the firing ring fits inside the main body, sort gets pressed in right? i can see there is a slight recess on the main body
The fire ring goes inbetween your wastegate and your manifold/wasegate flange.Acts as a valve seat if im not mistaken. Theyre usually not pressed in but they just sit in there and can fall out easily when the wastegate is not installed.
