waste controls boost?
Old Mar 1, 2003 | 12:37 PM
smallttocs's Avatar
Default waste controls boost?
hey guys im still new to the fi scene and im reading up on turbos still. i was wondering if the waste gate is the only thing that controls how much boost you are running or if theres other things that must be done to change the boost. thanks.
Old Mar 1, 2003 | 12:47 PM
ricodemus's Avatar
Default Re: waste controls boost? (smallttocs)
your wastegate is kind of like your "Default" setting for how much boost you are running. You can buy different springs for it, or you can get a boost controller. A MBC (manual boost controller) can be made for a few bucks. Do a search and find a ton more information.
Old Mar 1, 2003 | 12:58 PM
drift's Avatar
New User
Default Re: waste controls boost? (ricodemus)
the wastegate is the primary device for controlling boost by diverting exhaust gases away from the turbine to control turbine rpm at the wastegate spring's predetermined pressure setting.
Old Mar 1, 2003 | 05:05 PM
smallttocs's Avatar
Default Re: waste controls boost? (drift)
so a boost controler and / or waste gate are the 2 things that control your boost? anything else?
Old Mar 1, 2003 | 10:57 PM
Flamenco-T's Avatar
wastegate control your boost for the turbo...boost controller control your Wastegate...
Old Mar 1, 2003 | 11:06 PM
DIRep972's Avatar
Smarter than you
Default Re: waste controls boost? (Flamenco-T)
and ur hand controls ur boost controller.
Old Mar 2, 2003 | 12:30 AM
Dancing is Forbidden's Avatar
Default Re: waste controls boost? (DIRep)
My brain does not usually control my hands however (thats what I told the judge anyhow).
hold your breath
Mar 6, 2007 07:47 PM
thruvines87
Dec 6, 2004 10:00 PM
MachAF
Jun 27, 2003 05:14 PM
teamrocket si
Feb 10, 2002 02:27 PM
