Wanting to join the darkside
Old Jan 13, 2007 | 09:58 AM
BLUE EH3's Avatar
Help we my pennies
Default Wanting to join the darkside
I want t build a d16 for boost. What should be my move? head or block?
Modified by BLUE EH3 at 10:12 PM 1/20/2007
Modified by BLUE EH3 at 1:39 AM 4/7/2007
Old Jan 13, 2007 | 10:04 AM
JDM_EH2's Avatar
Default Re: Wanting to join the darkside (BLUE EH3)
Let me be the first to point you to the FAQ thread at the top of this page...
https://honda-tech.com/zerothread/1024174
Old Jan 13, 2007 | 10:23 AM
ProjectDarkBlack's Avatar
Default Re: Wanting to join the darkside (JDM_EH2)
start with headstuds
Old Jan 13, 2007 | 10:40 AM
93supercoupe's Avatar
Default Re: Wanting to join the darkside (ProjectDarkBlack)
research mang
Old Jan 14, 2007 | 02:57 PM
BLUE EH3's Avatar
Help we my pennies
where?
Old Jan 14, 2007 | 05:01 PM
wfocrx's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BLUE EH3 &raquo;</TD></TR><TR><TD CLASS="quote">where?</TD></TR></TABLE>
turbod16.com
d-series.org
Old Jan 14, 2007 | 05:04 PM
wfocrx's Avatar
I pieced together a kit using the sls mini log kit, t3/t04e turbo, 24x6x2 1/2"intercooler, 550cc injectors, chipped p28, 255lph fuel pump, 38mm wastegate, greddy type rs bov.
Old Jan 14, 2007 | 05:23 PM
blackeg's Avatar
Default Re: (wfocrx)
your options are very wide, mostly depending on how much money you are willing to spend. you can go hf manifold and saab t3 and get your goal for like 1000 bucks, or you can get a shelf kit for 3000 bucks.
mid to low 13s is gonna be in the low to maybe mid 200 whp range which is perhaps pushing it on a stock motor, especially for longevity. start with some headstuds, perhaps the zex cam and aftermarket im. gt28rs is perfect for this application but might be out the price range, so i might look toward a 50 trim t3t4 with a .48ar so it is spooled and going in the 4000 rpm range.
while on stock motor definately get a decent tune, i know jeff evans is close to jersey
Old Jan 17, 2007 | 11:52 AM
BLUE EH3's Avatar
Help we my pennies
Default Re: (blackeg)
I want to start working onmy fuel system, where should i start? is a bigger fuel rail needed?
Old Jan 17, 2007 | 01:03 PM
blackeg's Avatar
Default Re: (BLUE EH3)
stock fuel rail and fuel lines will work fine. you need to get larger injectors and probably a fuel pump just to be safe. (oe will work but for the 85 bucks its worth it to get a walbro)
Old Jan 17, 2007 | 01:08 PM
Fo-Do Fanatic's Avatar
for the fuel i would go with some 650's or maybe 550cc injectors. And if you wanna be a little baller a fuel rail. it wont be needed until you are around 450whp or so, but you'd have to sleeve your motor for that.
read the FAQ and you'll find almost every answer you need
Old Jan 18, 2007 | 08:38 AM
BLUE EH3's Avatar
Help we my pennies
i was always that bigger injectors are pointless witha bigger fule rail and ecu cappable of runnin bigger injectors
Old Jan 18, 2007 | 10:08 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BLUE EH3 &raquo;</TD></TR><TR><TD CLASS="quote">i was always that bigger injectors are pointless witha bigger fule rail and ecu cappable of runnin bigger injectors</TD></TR></TABLE>
well sometimes your fuel rail to provide your injectors with the correct amount of fuel.
Old Jan 18, 2007 | 10:15 AM
Default Re: (b00sted-Hatch)
the stock rail is good for alot of power.
With the right pump, i think it could even go way past 450.
Old Jan 18, 2007 | 11:14 AM
BLUE EH3's Avatar
Help we my pennies
Default Re: (Mr Wonderfull)
thank for all the great info, but im not goin over 300whp ona stock D block.. i just mid-low 13 car. This year my goal is to finsh my supsesion and my "preturbo parts.... can i use a ITR fuel pump?
Old Jan 25, 2007 | 10:34 AM
BLUE EH3's Avatar
Help we my pennies
AT 8psi what hp do d16 make.. what is consider a safe psi to boost on a stock block
Old Jan 25, 2007 | 10:51 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BLUE EH3 &raquo;</TD></TR><TR><TD CLASS="quote">AT 8psi what hp do d16 make.. what is consider a safe psi to boost on a stock block</TD></TR></TABLE>
maybe 200 or less.? dont really know much about d-series.
Old Jan 25, 2007 | 12:15 PM
blackeg's Avatar
jeez its such a broad question. your probably looking at about 160-180hp
Old Apr 5, 2007 | 12:11 PM
BLUE EH3's Avatar
Help we my pennies
what should be a first upgrade if im planning to go turbo? i have a spare d16 block i was think about building
Old Apr 5, 2007 | 04:50 PM
HiProfile's Avatar
Bone-stock, health D16z6: 220whp or less for safety. Above that you risk bent rods and cracked pistons (ringlands)
Bone-stock D16z6 w/forged rods/pistons: up to 350whp with ~20psi, as head is a big restriction. All parts are stock besides all of exhaust (turbo mani and full 3" turbo-back).
D16z6 w/intake, cam, head porting, and nice valve job: so far up to 450whp for some guys. Limited mainly by how high they want to rev.
You're posting in a sub-forum that has a capible search engine, 114094 topics, and 1269541 individual posts. I'm sure you can find something to start researching. There are a HUGE amount of FAQ posts as well as MANY "what do I need to go turbo?" threads. HOW many? Lets just say most moderators can't actually count that high.
Old Apr 6, 2007 | 05:47 PM
BLUE EH3's Avatar
Help we my pennies
I want to turn my Ek into a drag car once i get a new car in 2 yrs
EJ6JON
Group Threads
38
May 30, 2014 08:26 AM
StalX
Apr 21, 2007 02:25 PM
iBrandon
Jan 26, 2007 09:13 PM
FastAllmotorLsVtec
Jul 13, 2004 07:44 PM
B18Redline
Acura NSX
Jun 3, 2004 10:30 AM
