Walbro intank install help!
Old Jun 8, 2004 | 07:33 PM
Lost Type R's Avatar
Default Walbro intank install help!
I have my walbro clipped on all the OEM connections but is that white sack at the bottom of the pump necessary? I bought the walbro and it didn't come with a sack. If it is necessary, how do I disassemble it from the OEM pump onto the new one? http://www.c-speedracing.com doesn't say anything about it so I turn to you guys on this one. Thanks.
Old Jun 8, 2004 | 07:38 PM
hybrid88hatch's Avatar
Default Re: Walbro intank install help! (Lost Type R)
On my EF there was a small metal clip thing, that i took off first and them the little filter piece came off.I think you might wanna run that little filter, I'm guessing it keeps big chunks of debris from getting to your pump.
Old Jun 8, 2004 | 07:45 PM
turboteg2nv's Avatar
Default Re: Walbro intank install help! (hybrid88hatch)
Check with the dealer to see if you can get a new one first. If not, try to swap the other one. it's definetly something you need to ensure longevity of the pump and fuel sys.
Old Jun 8, 2004 | 08:13 PM
JDMH22HATCH's Avatar
Default Re: Walbro intank install help! (turboteg2nv)
Definitely run the filter. You don't want sediment and **** sucking up into the pump. I'd contact the person you got the pump from and get the filter that comes with the Walbro's
Old Jun 8, 2004 | 08:29 PM
Arturbo's Avatar
Better than steak
25 Year Member
Default Re: Walbro intank install help! (JDMH22HATCH)
There is a c clip on the stock pump. Take that off and use the filter off of the oem pump.
Old Jun 8, 2004 | 10:43 PM
Default Re: Walbro intank install help! (Arturbo)
Got it on! Thanks guys!
3easy21
Jun 6, 2012 09:21 AM
civic_66
Feb 27, 2009 03:43 PM
teddy_dc2
Jan 13, 2006 08:55 AM
Jared
Feb 1, 2004 05:27 PM
Halo
Feb 11, 2003 10:21 AM
