Walbro install, what did I do wrong?
Old Mar 20, 2009 | 02:06 AM
CRXdan's Avatar
Default Walbro install, what did I do wrong?
When coasting to a stop, pitch of whine changes from the pump.
Also, cruising on the highway with less than 1/4 tank the car cuts out and leans out like crazy.
When idling with less than 1/4 tank afrs are extremely inconsistent and fuel pump whine changes continiouslly.
Also, the fuel pressure guage pulsates.
Any ideas?
Old Mar 20, 2009 | 03:53 AM
boosted k20's Avatar
Default Re: Walbro install, what did I do wrong?
u either r using one of the smaller size fuel filter which doesnt pick up much fuel if the car is less than 1/4 tank or when u put the pump in, the fuel filter wasnt angled right in the tank
Old Mar 20, 2009 | 04:00 AM
Adriano's Avatar
The best thing is to take it back off and double check it. There's too many variables. Aslo, make sure your fuel level sender isn't out of wack and reading wrong (happened to me before)
Adriano
Old Mar 20, 2009 | 04:11 AM
DrivinVtec's Avatar
whenn you turn the car is this still pressure in the lines? few years back i tightend the hose clamp to tight and cut the feed hose. wasnt givin me enough fuel. just and idea.
Old Mar 20, 2009 | 07:56 PM
CRXdan's Avatar
I figured it out today. The pump was not sitting low enough in the tank. I had to modify the pump bracket and extend the line to make it sit lower to grab fuel from the bottom of the tank.
Undergroundeg6
Jul 19, 2013 01:23 PM
Gabe87CRX
Classic Hondas
Apr 18, 2010 09:47 PM
pr3lude1992
Feb 18, 2009 06:30 PM
hybrid ef
Mar 15, 2006 06:51 PM
IAteg
Nov 11, 2005 12:34 PM
