walbro 255
Old Mar 19, 2009 | 06:25 AM
j_kevin_ca's Avatar
Default walbro 255
hi, all
i was just wondering if i needed a 255 lph or 255lph HP for a 300+whp sohc turbo set up.
one more question is are all the pumps the same from EF to EK? i got two different product numbers from procivic.com but some guy told me that its all the same. anybody can clarify that for me? thx, H-T!
Kevin
Old Mar 19, 2009 | 10:24 AM
Muckman's Avatar
Moderator in Chief
Default Re: walbro 255
Either model walbro would be enough for 300hp. even the 190lph model.
But I think its worth to spend a little extra and get the 255hp
Old Mar 19, 2009 | 10:55 AM
Ls_dx's Avatar
Probably go with the 255hp. And go with the right part number for your car. It will make your life easier.
Old Mar 19, 2009 | 11:10 AM
TheShodan's Avatar
Moderator
Walboro255 part number 342 is what you need.
Old Mar 20, 2009 | 05:44 AM
j_kevin_ca's Avatar
is this for a 92-00 civic?
Old Mar 21, 2009 | 11:35 PM
Tony the Tiger's Avatar
The GSS-342 pump will fit your Civic.. The difference between the 341 and 342 is the location of the inlets and outlets on the pump. The OEM electrical connector will plug into either pump. If you get the Civic model pump, the only difference is the installation kit which comes with a different sock filter for the pump.
Old Mar 22, 2009 | 01:36 AM
grndcont's Avatar
STOP! the 255lph hp is for high pressure setups, like if you are using a vortech fmu. if you plan on running the stock fuel regulator and the stock fuel pressure, just get the 255 lph.
k24killer
Aug 14, 2007 09:53 AM
ShawnR
Nov 17, 2006 07:23 PM
_Endless_
Oct 27, 2004 06:44 AM
SiRkid
May 16, 2003 07:44 AM
R6Boy69
Jul 3, 2001 08:27 PM
