walbro 190 be enough?
Old Aug 8, 2007 | 06:37 PM
94c1v1cex's Avatar
Default walbro 190 be enough?
building a hmt kit for my ej1 with d15b swap. using dsm 14b turbo and 450 injectors. will a walbro 190 be enough or should i get the 255? thanks
Old Aug 8, 2007 | 06:44 PM
agrn93ls's Avatar
Default Re: walbro 190 be enough? (94c1v1cex)
if you have the option go with the 255.
*edit* its not an option get the 255
Old Aug 8, 2007 | 06:50 PM
94c1v1cex's Avatar
Default Re: walbro 190 be enough? (agrn93ls)
that made no sense....
Old Aug 8, 2007 | 06:51 PM
94c1v1cex's Avatar
reason i'm asking is i can get a walbro 255 for 85 bucks in sponsor marketplace but my friend has a 190 that he'll sell me for 50 bucks...
agrn93ls's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 94c1v1cex &raquo;</TD></TR><TR><TD CLASS="quote">that made no sense....</TD></TR></TABLE>
neither does you askin if you should get a 190 or a 255
Old Aug 8, 2007 | 06:54 PM
94c1v1cex's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by agrn93ls &raquo;</TD></TR><TR><TD CLASS="quote">neither does you askin if you should get a 190 or a 255</TD></TR></TABLE>
uh ok... am i not entitled to ask a question?
Old Aug 8, 2007 | 07:02 PM
bootlegcivic's Avatar
MK3tuner sells 255lph for $90 plus 4-5 dollars shipping on ebay hooked me up!!! mine as well get that.
http://cgi.ebay.com/ebaymotors...ZWDVW
Old Aug 8, 2007 | 07:08 PM
agrn93ls's Avatar
the answer i gave was par for the question.
you asked what to do. i said if you have an option go 255. then i implied it should not be an option that you consider by saying "its not an option get the 255"
then you said that dont make sense, then i said neither does you wanting to get a 190lph fuel pump when you have an option to get a 255lph. that was before i knew about the pricing
damn dude you just made me feel alot better about talking to my gf. i thought she was hard to relate to LOL
but above all that how can anyone know the answer without knowing what you plan on putting out with it? just make life easier and get the 255 so there is nothing to worry about. i was trying to make a long answer short.
Old Aug 8, 2007 | 07:10 PM
94c1v1cex's Avatar
ya man my question still hasn't been answered... i see what you're saying but why spend 35-40 more bucks if a 190 will be enough to serve the purpose...
edit: i know 40 bucks isn't alot but for a college student that only works 3 days a week it's alot
Old Aug 8, 2007 | 07:16 PM
agrn93ls's Avatar
i see. yeah thats a few meals and a couple 30 packs of keystone's
well the 190 is better than stock of course and would think it could support around 300-350 just fine but i dont honestly know so ill quit jackin up your thread
some have said the 255 is good to the 500 ish range.
and the less pressure you run the more lph the pump flows so if you keep the pressure in a lower range close to stock i would think you would be fine here is a graph of what happens when you compare PSI to flow on a 255
Old Aug 8, 2007 | 10:20 PM
mike93eh2's Avatar
i was making 400whp on my d16 with a 190...
have since switched to 255.
Old Aug 8, 2007 | 11:56 PM
poundedhatchcrap's Avatar
Default Re: (mike93eh2)
just go with the 255, you wont have any thoughts of "is it going to be enough" in the back of your head. And if you can get either one then just get the nicer one and be done with it. Like a added sense of security IMO
Old Aug 9, 2007 | 05:08 PM
94c1v1cex's Avatar
Default Re: (poundedhatchcrap)
well i'm only gonna be makin 250... the car is a dd from what i've seen i think the 190 will be plenty
Old Aug 9, 2007 | 11:41 PM
sohc_turd's Avatar
Default Re: (94c1v1cex)
i still run a 190 at stock fuel pressure for my setup, so for your goals it should be fine.
EDIT: although i did hot wire it straight off the alternator.
Old Aug 10, 2007 | 10:13 AM
Flashmn's Avatar
Default Re: (sohc_turd)
If theres only 30 dollar difference I'd get the 255 and be done with it.
Old Aug 10, 2007 | 10:35 AM
GiNuWiNe's Avatar
Default Re: (Flashmn)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Flashmn &raquo;</TD></TR><TR><TD CLASS="quote">If theres only 30 dollar difference I'd get the 255 and be done with it.</TD></TR></TABLE>
So would i, your always going to want more.
sikciv666
Jun 9, 2006 08:11 PM
iHOPEyouCHOKE
May 24, 2006 02:11 PM
all_out_jdm
Oct 17, 2005 09:35 PM
RACEPAK
Jun 23, 2005 06:17 AM
hondaguyef
Apr 28, 2005 12:11 AM
