w.inline fuel pump install
Old Nov 17, 2002 | 12:56 PM
B18C-RnVA's Avatar
New User
Default w.inline fuel pump install
i just got fuel pump..need to install tomorrow..i thinkit goes in between the fuel filter and fuel rail, could some one give me directions to install it...as simple as you can make the instructions...thanks...
Old Nov 17, 2002 | 01:03 PM
RAWB's Avatar
Default Re: w.inline fuel pump install (B18C-RnVA)
Cut line from Fuel Filter to rail, using hose clamps- install inline pump(direction should be specified on pump), wire the "hot" wire to 12v ignition source, and ground the other.
[Modified by integracon, 2:05 PM 11/17/2002]
Old Nov 17, 2002 | 01:08 PM
B18C-RnVA's Avatar
New User
Default Re: w.inline fuel pump install (integracon)
so ican run the hot wire off my battery, ground the other wire and thats it..as far as wiring is concered..
Old Nov 17, 2002 | 01:10 PM
RAWB's Avatar
Tap it off of a 12v ignition source.
Old Nov 17, 2002 | 01:31 PM
B18C-RnVA's Avatar
New User
and where would that be at
Old Nov 17, 2002 | 01:36 PM
RAWB's Avatar
Do you have a Helm's manual? I have a 91 Integra so I could tell you a few sources for that car- not sure about yours. Maybe someone with a G3 can.
[Modified by integracon, 2:37 PM 11/17/2002]
Old Nov 17, 2002 | 01:50 PM
Etylorcen's Avatar
Make sure u secure the fuel pump down so it doesnt move at all so there isnt any way for the fuel lines to come loose some how. Last thing you want is to be flying down the road and a fuel line comes loose spraying fuel all over a hot engine.
Old Nov 17, 2002 | 01:53 PM
B18C-RnVA's Avatar
New User
Default Re: w.inline fuel pump install (Etylorcen)
alright..i dont have a helms..i need to invest in one..but the fuel pump already has the relay on it and everything i just need to find the 12v source to tap from..anyone with a G3 teg(gsr) please help..
Old Nov 17, 2002 | 02:21 PM
B18C-RnVA's Avatar
New User
alright i have my fuel pump i have the relay on it..and i have used 85 to run to the fuel pump, i ran the ground straight from the bottom of the fuel pump and gonna ground it, of course on the car. i was wondering could i use 14guage wire from the battery to the relay to make my pump work??? help
also do i need to run a wire for constant, stock fuel pump to the relay?? Also where would i tap for that source if i have to? sorry for asking so many question..lol..
[Modified by B18C-RnVA, 11:27 PM 11/17/2002]
Old Nov 18, 2002 | 02:08 AM
B18C-RnVA's Avatar
New User
ttt
Old Dec 8, 2002 | 10:05 AM
B18C-RnVA's Avatar
New User
help
Old Dec 8, 2002 | 10:12 AM
T-sohctec's Avatar
Am I reading this correctly?
Did you get power directly from your battery?!
Good luck, I hope your car doesn't get too crispy
Old Dec 21, 2002 | 04:02 AM
B18C-RnVA's Avatar
New User
Default Re: w.inline fuel pump install (T-sohctec)
no ididnt get the power from my battery
HT Chaplain
Jan 10, 2006 05:12 PM
wade
Jul 1, 2004 08:47 AM
EFSiR
May 14, 2004 09:32 AM
JICsube
Sep 11, 2002 06:38 PM
TORQUE MONSTER
Aug 15, 2002 05:15 AM
