vtec setting
Old Sep 12, 2006 | 12:55 PM
rdeezy78's Avatar
Default vtec setting
Where are you FI guys setting your vtec at? Is 4800 too low for a b16a?
Thanks
Old Sep 12, 2006 | 12:57 PM
Boostage's Avatar
Default Re: vtec setting (rdeezy78)
Its usually set wherever its needed. each motor is different.
Old Sep 12, 2006 | 01:37 PM
Mugencrxsir1's Avatar
Default Re: vtec setting (Boostage)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Boostage &raquo;</TD></TR><TR><TD CLASS="quote">Its usually set wherever its needed. each motor is different.</TD></TR></TABLE>
Yeap, each motor is different, but if you are messing around with your own ems, then it's a trial and error w/o having a dyno. I wouldn't even bother unless you are on a dyno, and know what your doing, otherwise you will most likely slow your car down.
Old Sep 12, 2006 | 02:18 PM
OBRJosh's Avatar
Default Re: vtec setting (Mugencrxsir1)
I have mine at 5600 with gsr cams hits hard
Old Sep 12, 2006 | 03:06 PM
rdeezy78's Avatar
Default Re: vtec setting (OBRJosh)
I'm sure I hace stock cams and I have aem cam gears but on my dyno chart when the vtec hits I either lose or level off for like 2-300 rpms b4 it shoots up. I wanted to drop the setting down a little so it would be a smoother kick, It's set at 5600 now.
Old Sep 12, 2006 | 03:29 PM
OBRJosh's Avatar
Yea if you have it on to earlly it will kill your powerband, id say once you start building a couple Lbs then turn it on
TurboEG6262
Mar 8, 2013 12:39 PM
hondacrx2
Nov 16, 2007 02:28 PM
DETOUR180
Aug 16, 2007 04:14 PM
01ITR#700
Jun 4, 2004 11:43 AM
rev-speed
29
May 1, 2004 10:12 AM
