vortech keeps breaking belts
Old Jun 19, 2005 | 07:09 AM
sproket13's Avatar
Default vortech keeps breaking belts
well, in 7 days, ive gone through 6 belts. some last longer than others. all have been from autozone, which is probably the problem. they carry dayco belts..which apparently are no good. so whats a good belt?
Old Jun 19, 2005 | 07:14 AM
twkdCD595's Avatar
Default Re: vortech keeps breaking belts (sproket13)
doesn't goodyear or someone like that make a gator belt that will fit... sorry not for sure.
are you sure everything is ok with your setup, cause that many belts breaking?
Old Jun 19, 2005 | 07:19 AM
sproket13's Avatar
Default Re: vortech keeps breaking belts (twkdCD595)
everythign is fine...all lined up..boosts the 8 psi that it should. i just noticed after a day of use, the belts start to show wear ont he side, and start to fray. ive tightened the belts but im afraid to over tighten..when i give it gas, it used to torque just a lil (the belt) but now it dosent move at all, so i figured this last time i got it right..size and tightness, but it broke last night
Old Jun 19, 2005 | 07:42 AM
HitEm'Up's Avatar
I work for a NAPA here and we stock Gates belts! I've got a jackson on my hatch and have ran these belts with no problems
Old Jun 19, 2005 | 07:55 AM
sproket13's Avatar
Default Re: vortech keeps breaking belts (HitEm'Up)
then thats what i need to get..
Old Jun 19, 2005 | 09:57 AM
Tyler H's Avatar
If it's fraying on the side after one day's use, you have a major alignment issue. That shouldn't be happening, no matter what brand belt. Fix your pulley alignment issue first, belt brand shouldn't matter.
Tyler
Old Jun 19, 2005 | 03:57 PM
sproket13's Avatar
Default Re: vortech keeps breaking belts (Tyler H)
figured out what it was...the bolt on the lower part of the powersteering apparently came out...glad it was that bolt i forgot to tighten, not a more important one..so anyways, the powersteering was moving over, making the belts rub, and for some reason, it kept takin out the SC belt never the power steering so i just got a gatorback belt and running w/o powersteering...so far today, no wear on the belt is evident
1baddcivicsi
May 3, 2009 10:23 PM
scottmog
Dec 18, 2008 09:15 PM
invisible
Jun 1, 2008 09:38 PM
amej8
Jun 1, 2007 09:00 PM
silvercivichatch
Dec 20, 2004 06:45 PM
