Vortech Fuel Pressure Optimizer, is it a good idea?
Old Jan 14, 2006 | 02:54 PM
integra3586's Avatar
Default Vortech Fuel Pressure Optimizer, is it a good idea?
need opinions on the vortech Fuel Pressure Optimizer, is it worth the investment? are they safe? i cant tell but i almost looks like how the b&m fpr installs, keeping the stock oriface.
go here for more details http://www.vortechsupercharger....html
Modified by integra3586 at 7:48 PM 1/19/2006
Old Jan 19, 2006 | 06:46 PM
Default Re: Vortech Fuel Pressure Optimizer, is it a good idea? (integra3586)
i know someone knows sumthin about this, or has it
Old Jan 19, 2006 | 07:04 PM
mrbsponge's Avatar
looks like a B&M copy
Old Jan 19, 2006 | 07:06 PM
Default Re: (mrbsponge)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mrbsponge &raquo;</TD></TR><TR><TD CLASS="quote">looks like a B&M copy</TD></TR></TABLE>
b&m good or bad? i am looking for a fpr i want somthin good i dont mind spending the money for sumthin good
Old Jan 19, 2006 | 07:14 PM
iam7head's Avatar
Default Re: (integra3586)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by integra3586 &raquo;</TD></TR><TR><TD CLASS="quote">
b&m good or bad? i am looking for a fpr i want somthin good i dont mind spending the money for sumthin good</TD></TR></TABLE>
i have b&M for 4+years now, works like new
i think mine was like 50 buck but you'll need to tap your line for the fuel pressure reading somewhere(i use a banjo bolt and a liquid filled guage)
Old Jan 19, 2006 | 07:17 PM
Default Re: (iam7head)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by iam7head &raquo;</TD></TR><TR><TD CLASS="quote">
i think mine was like 50 buck but you'll need to tap your line for the fuel pressure reading somewhere(i use a banjo bolt and a liquid filled guage)</TD></TR></TABLE>
where did you get you banjo bolt? will it work with an autometer mechanical gauge?
Old Jan 20, 2006 | 03:20 AM
rudebwoy's Avatar
they sell a gauge kit that installs on the top of your fuel filter, check summit racing,or ebay
http://cgi.ebay.com/ebaymotors...wItem here is one there are many options
Old Jan 20, 2006 | 02:37 PM
Default Re: (rudebwoy)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by rudebwoy &raquo;</TD></TR><TR><TD CLASS="quote">they sell a gauge kit that installs on the top of your fuel filter, check summit racing,or ebay
http://cgi.ebay.com/ebaymotors...wItem</TD></TR></TABLE>
thanks man thats what i was looking for
Old Jan 20, 2006 | 02:45 PM
Synapse's Avatar
I'm way biased, but check out the Synchronic unit. You can change out the bypass size to compensate for different flow fuel pumps and if you go turbo later, you can even use it for low boost, or just as a 1:1 with uberdata, EMS, whatever.
http://www.streetrays.com/cata...10274
Old Jan 20, 2006 | 02:51 PM
Default Re: (Synapse)
i forgot to mention i have a vortech s/c kit with the 255lph walbro pump, 310cc rc injectors and the vortech 6:1 fmu &lt;---------------temporary till i get my chrome set up tuned,
will the b&m fpr work with my setup?
Old Jan 20, 2006 | 03:08 PM
Synapse's Avatar
The problem is that you need something that will allow you to adjust the flow of the 255 pump. So an FPR with interchangeable bypass fittings, like the AEM or Synchronic unit.
With the 255 you can't turn your fuel pressure lower than 50 psi right now because the flow of the pump is exceeding the diameter of that bypass. I don't think that the unit you're looking at will work.
Old Jan 20, 2006 | 03:10 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Synapse &raquo;</TD></TR><TR><TD CLASS="quote">The problem is that you need something that will allow you to adjust the flow of the 255 pump. So an FPR with interchangeable bypass fittings, like the AEM or Synchronic unit.
With the 255 you can't turn your fuel pressure lower than 50 psi right now because the flow of the pump is exceeding the diameter of that bypass. I don't think that the unit you're looking at will work.</TD></TR></TABLE>
thanks for ur help, Anyone else?
Old Jan 20, 2006 | 03:15 PM
rudebwoy's Avatar
what are you saying?
I run 42 psi fuel pressure with walbro 255lph,aem fpr, and rc 750cc with uberdata with no issues
Old Jan 20, 2006 | 03:17 PM
he was saying with a vortech fpr, you wouldnt be able to run below 50 psi, i guess cause it utilizes part of the stock fpr
Old Jan 20, 2006 | 03:18 PM
I run 42 psi fuel pressure with walbro 255lph,aem fpr, and rc 750cc with uberdata with no issues</TD></TR></TABLE>
how do you like your aem fpr? how old is it? the reason im asking is because someone told me the aem is prone to diaphram failure
Old Jan 20, 2006 | 03:19 PM
Synapse's Avatar
The bigger injectors act like a bigger bypass because their openings are larger than the stock injectors. My statement only applies if you are still using the stock FPR and stock injectors. Did you also run the larger bypass fitting on the AEM regulator?
750's are kinda big compared to stock, but for the 310's he's running they may not be large enough to drop the fuel pressure 10 psi at idle under vaccum.
Old Jan 20, 2006 | 03:26 PM
have you guys heard anything on the aeromotive fpr?
Old Jan 20, 2006 | 03:30 PM
Synapse's Avatar
Like I said, I'm kinda biased because I designed it, but the Synchronic FPR is the only one that doesn't use a diaphragm, period.
I like the AEM over the Aeromotive because it can compensate for the pump flow like I said earlier, and I'm not a big fan of the thin mounting flanges on the Aeromotive unit.
Although at the end of the day, both still have diaphragms . . .
Old Jan 20, 2006 | 03:33 PM
is streetrays.com ur website? if so would i get a h-t hookup? if so pm me a price
Old Jan 20, 2006 | 03:40 PM
Synapse's Avatar
sorry, I just design and mfg it. Streetrays is just one of the HT vendors I know that carries it and takes care of customers.
Old Jan 20, 2006 | 03:43 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Synapse &raquo;</TD></TR><TR><TD CLASS="quote">sorry, I just design and mfg it. Streetrays is just one of the HT vendors I know that carries it and takes care of customers.</TD></TR></TABLE>
oh ok, well i will consider getting one of these. i think i ruled vortech and b&m out
Old Jan 21, 2006 | 04:03 AM
rudebwoy's Avatar
how do you like your aem fpr? how old is it? the reason im asking is because someone told me the aem is prone to diaphram failure</TD></TR></TABLE>
I bought it used off here, it seems like the guy used for a while also, and it was in the for sale section for about a year, I've been using it for 7000 plus miles, and before that I was using the b&m with dsm 450cc.
I would like to give the synchronic a try but I dont do any tuning with my fpr, I just set it to stock and tune with uberdata. so it would be pointless to change now.
AZNracerx1989
Jul 13, 2006 08:25 AM
88crxhfb16
Jul 7, 2005 02:21 PM
Corporation
Jul 27, 2004 09:19 PM
n2oteg
Apr 13, 2004 06:06 PM
CM-R
Feb 9, 2002 02:06 AM
