Volvo Flange
Old May 24, 2005 | 06:05 AM
saxqtzk's Avatar
Default Volvo Flange
Hey Guys,
I've found topics that covered this either on this site or turbod16 but most of them were questions on mounting them on HF/STD manifolds and were answered with weirracing adapter plates.
Besides having it sanded down what other options do I have to mount this type of flange? I intend on mounting it to a manifold like BMCRace which uses a traditional T3 flange.
It'll mount but the top portion of the circular part of it sticks out and will leak. Even if I had a round gasket there's nothing to push down on it to prevent it from leaking. I would consider welding it but If the turbo craps out it'll be a pain to remove from the manifold.
If I were to find someone who'll make an adapter plate that is longer and wider but still use the traditional bolt pattern and inlet hole, could I mount that in between the turbo and the manifold with using longer bolts? Basically, I just need the plate to cover the top and bottom portion that is protruding out.
Thanks guys.
BTW, it's off a Volvo 740 (TB03)
http://www.we-todd-did-racing....D.jpg
Old May 24, 2005 | 06:08 AM
plohip2's Avatar
Default Re: Volvo Flange (saxqtzk)
make our own. trip to hardware store + dremel = adapter.
Old May 24, 2005 | 06:19 AM
saxqtzk's Avatar
Default Re: Volvo Flange (plohip2)
Thanks for the reply,
well, i'm looking for something that's stainless steel. I don't think a dremel is sufficient enough. Plus, If I have to pay someone to machine it for me I rather do that than mess with it myself because I intend on leaving it on the car for a while. I don't want to make something that either doesn't fit properly, or blocks any air.
I've already contacted weirracing and bmcrace but trying to see if you guys have any other suggestions.
Old May 24, 2005 | 06:22 AM
Bailhatch's Avatar
I just weld the little half moons shut and then plane it flat. I have been running .63 done like this for a long time and have done it for others. Send it to me and I'll do it for you if you want.
killacamcivic
Mar 9, 2011 10:37 PM
Mixmasta
Sep 18, 2009 10:17 AM
Boostage
Feb 2, 2009 07:12 PM
Acura_I-RS
Jan 3, 2003 10:20 AM
GOLDBERG
Dec 26, 2002 06:40 PM
