which vitaras ?
Old Jun 29, 2007 | 03:19 AM
hany's Avatar
Default which vitaras ?
i went today to buy vitaras pistons . and i found injection engine and carb engine . and when i look at the code i found g16a and g16b
so my question is which vitara i choose ? for injection or carb engines ?
Old Jun 29, 2007 | 04:23 AM
MeanGreenMachine's Avatar
Default Re: which vitaras ? (hany)
buy the ycp vitara pistons from honda tech member FJT
Old Jun 29, 2007 | 04:32 AM
fjt's Avatar
fjt
Piston code is G16b.. 16 valves.
Which pistons are you getting? Not all vitara pistons will produce the same results(power).
Old Jun 29, 2007 | 01:26 PM
hany's Avatar
Default Re: (fjt)
iam from EGYPT. so it hard to buy from you
i found a block coded with G16B and i took that pistons is that right ?
Sajmon_LP
Feb 10, 2011 07:16 AM
erebunicrx
Nov 7, 2004 05:59 AM
