valve train question
Old Oct 13, 2013 | 09:16 AM
turboef90's Avatar
Default valve train question
im gonna be only at the 450hp tops and not reving past 8000 with gsr cams.im thinking of using ST valvetrain. i know ferrea is what everyone is leaning towards but seems like there all in the like 700+ rang and reving past 9500 rang as well. thoughts??
this is the kit im looking at as well http://www.ebay.com/itm/SUPERTECH-VALVE-TRAIN-KIT-TURBO-HONDA-ACURA-B16-B18-GSR-SI-DUAL-VALVE-SPRINGS-/331040187109?pt=Motors_Car_Truck_Parts_Accessories&hash=item4d138862e5&vxp=mtr
Old Oct 13, 2013 | 12:42 PM
boosted94gsr's Avatar
Default Re: valve train question
Why not just stick with oem valve spring and retainers if ur gonna stay with stock cams and rev limit?
Old Oct 13, 2013 | 03:20 PM
$MIKE$'s Avatar
this is the kit im looking at as well Supertech Valve Train Kit Turbo Honda Acura B16 B18 GSR SI Dual Valve Springs | eBay
those are what I got it works great go with it.
Old Oct 13, 2013 | 07:49 PM
Muckman's Avatar
Moderator in Chief
Even at stock red line the demand for valve spring increases with boost & exhaust pressure. You'd be fine with simply the dual valve springs. You honestly dont need the rest of the kit for your goals.
Old Oct 13, 2013 | 08:25 PM
TheShodan's Avatar
Moderator
I agree.. the valvetrain is fine enough. No need for all the rest.
Old Oct 13, 2013 | 08:53 PM
Hidenplanvew's Avatar
Just get the ST valve springs and keep ur OEM Retainers and locks... Tit retainers are a wear item and I have seen a few split in 1/2 no matter what brand it is.
Old Oct 13, 2013 | 09:36 PM
TheShodan's Avatar
Moderator
Ti are fine when installed properly. I'm still on the same set 10 years later. No cracks and no splits. 200K on the clock, and has past through 3 family members.
Old Oct 14, 2013 | 02:07 AM
Balor_Gr's Avatar
Well i would be sceptic on those 15-20 years old retainers too...
Old Oct 14, 2013 | 03:38 AM
blackeg's Avatar
then compromise with the 02 rsx retainers, they are new and cheap.
i use the 85lb supertech springs with ti retainers they hold up well. ive had it up to 9400 rpm or so when i hit the limiter a few times coming out of 1st and 2nd gear
maverick_dc5
May 28, 2014 08:11 AM
turbolshatch
Oct 5, 2007 08:43 AM
import_king20
Mar 18, 2006 05:08 AM
bcube 1
21
Aug 10, 2005 10:20 AM
