VAFC question?
Old Aug 20, 2002 | 07:31 PM
forcedaccord95's Avatar
Default VAFC question?
I have a 95 accord, ex, 2.2 vtec, it has the f22-b1 motor in it with a turbo on it. I just bought a vafc controller for it and have ran into a couple of questions. one instruction sheet that came with the controller did not have my car on it. I called apexi and they said that the controller does not like my car (it doesn't like the vtec). he said that I needed the safc controller, which is the same controller with out vtec. I was reading the book that it came with, not the same peice of paper, and it had all the diagrams I needed to hook it up to the f22-b1, I am confused, they said not to use it but its in the book? my question is, can I hook it up without the vtec controller hooked up? Another question, does any body have this set up and if so how is it working? please let me know .....thanks
Old Aug 20, 2002 | 07:57 PM
T25 civic's Avatar
Default Re: VAFC question? (forcedaccord95)
I was told that you can still use the V-AFC just not hook up the wires for the v-tec portion of the controller. Not sure if thats true(I hope so cause it was from a performance shop). I am planning on doing a v-tec swap after I put in my turbo (just two more weeks and I should be installing it!!!!!!) and the shop said that I could get the V-AFC and just not hook up the v-tec portion untill I get the v-tec swap.
Nick
Old Aug 20, 2002 | 08:14 PM
Default Re: VAFC question? (T25 civic)
thanks, does any one know if this is true?
Old Aug 21, 2002 | 02:43 AM
niedejb's Avatar
The VAFC works fine on the F22b1. Get yourself a service manual and wire it up correctly. I hear this all the time but never had any trouble with mine.
I dropped my vtec down to 3100 to get more power earlier. Dont know if its just my car but, the dyno showed my best runs at 3100.
[Modified by niedejb, 5:43 AM 8/21/2002]
Old Aug 21, 2002 | 07:29 AM
Default Re: VAFC question? (niedejb)
do you have the wiring diagram for the ecu, or do you know where I can get it
devnull
Honda S2000
Jun 22, 2005 07:35 PM
LU
Sep 29, 2004 01:28 PM
RRRex
Jun 24, 2003 11:09 PM
