vafc hack on OBD2...??
Old Jan 24, 2004 | 12:51 PM
tyflip2's Avatar
Default vafc hack on OBD2...??
what is needed to do the vafc hack on an obd2 car. is it the same as with an obd1 which is just the injectors and the crx resistor box. will i need to do anyhitng else? thanks for any help
Old Jan 24, 2004 | 01:17 PM
tyflip2's Avatar
Default Re: vafc hack on OBD2...?? (tyflip2)
do i need to get the harness to change to obd1?? need help!
Old Jan 24, 2004 | 02:41 PM
99blackcivicSi's Avatar
use the pinout and wire it up
Old Jan 24, 2004 | 05:08 PM
scttydb411's Avatar
afc, resistorbox, and injectorclips unless you want to spend time hacking up the obd2 clips. i would also recommend an msd btm to retard timing a little under boost, but it's not necessary. you will more than likely get a cel for baro sensor, but it won't affect anything.
wire it up and enjoy!
Old Jan 24, 2004 | 10:09 PM
civicshowracing65's Avatar
it also depends what you go with...
dsm injectors = resistor box + obd-1 clips + vafc + (4) injector seal kits & boring the seals out
lucas, rc, etc = obd-1 clips + vafc
Old Jan 25, 2004 | 04:59 AM
T-RO's Avatar
Out of curiosity what is different about the OBD2 injector clips?
I'm OBD1 so havent seen them.
Old Jan 25, 2004 | 07:51 AM
2SLO's Avatar
Default Re: (T-RO)
alittle off topic but where can i send my injectors to get cleaned and ballanced? dsm 450's... got em from the scrap yard fo FIVE dollas y0... im so 1337
Old Oct 22, 2004 | 09:33 PM
JdmEKCivic's Avatar
Default Re: (2SLO)
Yo can send them to RC Injectors. I think the turn around time is 1week
Maleek
May 17, 2012 08:47 PM
BB6matik
Aug 15, 2010 05:54 PM
RACEPAK
Jul 19, 2005 09:51 AM
S9 MECHA KARUMA
May 20, 2002 01:35 PM
