... vafc hack... low boost (5-7psi)... stock timing?
Old Oct 4, 2002 | 11:56 AM
1.8T_EG's Avatar
Default ... vafc hack... low boost (5-7psi)... stock timing?
... soon to be vafc hack... will be running low boost (5-7psi)... i was wondering if i will be alright with stock timing (16*+/-2)... or should i retard on the distributor 1 or 2 degrees... lemme know... thanks...
Old Oct 4, 2002 | 12:42 PM
CzanSOHC's Avatar
Default Re: ... vafc hack... low boost (5-7psi)... stock timing? (1.8T_EG)
you should be fine, maybe retard 1 degree, runing 93+ octane.
Old Oct 4, 2002 | 12:49 PM
mos's Avatar
mos
Default Re: ... vafc hack... low boost (CzanSOHC)
I might be trying something similar soon, and was wondering about ignition timing also: SMC-450cc-7psi-91octane-stock ignition. I'll be sure to retard it a couple degrees to start off with.
Old Oct 4, 2002 | 01:35 PM
RuthlessEF-9's Avatar
Default Re: ... vafc hack... low boost (mos)
why not retard the cam instead of the dizzy
Old Oct 13, 2002 | 06:36 AM
BoostedED9's Avatar
Default Re: ... vafc hack... low boost (D16z6turbs)
im going to be running about 8psi on my setup and will have a msd btm, should i drop the timging about 1* then like .5*/lb of boost????
Old Oct 13, 2002 | 09:00 AM
Elite Hatch's Avatar
I personally wouldnt touch cam timing.
Old Nov 3, 2003 | 04:39 AM
Snail Tuning's Avatar
because cam timming is totaly differnt.
i ran stock timming at 8psi on a b16a on 92 octain no problems.
im running stock timming on my d15 7.5psi no problems. u can retard thetimming with the edizzy like 1deg but i wouldn;t go much more. also the btm i used that when iwas at 10psi 3/4 deg per psi worked great.
Old Nov 3, 2003 | 08:15 AM
scttydb411's Avatar
i didn't touch my timing...just retarding it w/ btm 1/2 degree per pound of boost. been boosted for over 12k miles on d16y7...10-11psi for 3-4k miles.
Old Nov 4, 2003 | 09:43 AM
Del_Slowest's Avatar
Default Re: (scttydb411)
stock cam is perfect for boost. the overlap is very minimal with is what you want with forced induction.
Stock ignition timing is different. most people say retard 1 degree per pound of boost. just play with it, retart a lot then work your way back until you get the first sign of detonation. then take it back 2 degrees from that point.
asianspeed
Aug 8, 2003 05:05 AM
Licensed2Spool
Apr 9, 2003 06:22 AM
rudebwoy
Mar 29, 2003 08:55 AM
BorderM3
Dec 30, 2002 11:40 AM
1.8T_EG
Sep 17, 2002 02:47 PM
