V-AFC Installed....now I get CEL
Old Sep 12, 2002 | 07:29 AM
Hellz99si's Avatar
Default V-AFC Installed....now I get CEL
Well~ I Installed the AFC yesterday and I soldered all connections EXCEPT the vtm wire which I did install....but it was getting late...I'll solder that today. After I did the initialize 6in 6 out 4cyl throttle up and all that crap the car idle great and I let the ECU go through it's re-program. I took it for a drive and everything seemed fine no CEL but just as was about to park the CEL came on and wouldn't turn off it even shows with the key to the ON position. I reset the ECU and same outcome about 10min later the CEL came on....also this morning I had no vtec at normal operating temp. Which wires should I check? I'm going to look at the VTM and the VTEC solenoid wires again they may be loose or something. Any help appreciated. Thanks.
Old Sep 12, 2002 | 07:33 AM
mntdewred's Avatar
Default Re: V-AFC Installed....now I get CEL (Hellz99si)
check the code and recheck all the wires.
Old Sep 12, 2002 | 08:27 AM
Hellz99si's Avatar
Default Re: V-AFC Installed....now I get CEL (mntdewred)
I actually am getting VTEC I just had it set high but I still have that cell...I think it is probably just that VTM wire....thanks for the reply though
Old Sep 12, 2002 | 08:41 AM
98civicEX's Avatar
if the VTM wire isn't hooked up then you won't hit VTEC, it'll just be rev limiter pretty much. yes check all the wires. fuel pres. and VTM. make sure none of them are crossed and that they have good solid connections. keep us updated.
Old Sep 12, 2002 | 08:44 AM
mntdewred's Avatar
do you know how to check what kind of code you are throwing? could be something completely different than the V-AFC, maybe its just a coincidence.
Old Sep 12, 2002 | 09:37 AM
Hellz99si's Avatar
===> Me
I spliced the bottom left wire on the right plug instead of the top right!!!!! for the VTM! It's running fine now no CELs and everything is good....in the middle of the night you kind of get tired and don't think straight....
Thanks guys....VTEC is strong set to 5500 engage, 4800 disengage...all good...
[Modified by Hellz99si, 7:54 PM 9/12/2002]
Old Sep 12, 2002 | 01:26 PM
M.A.R.C.'s Avatar
heheheh all good... i did my vafc install at like 1 in the morning with a flashlight and i accidentally cut the wrong wire (i cut the IACV instead of TPS i think it was) so i had an IACV cel, and i drove it around wondering wtf. rechecked everything and i realized... it was dark so i cut the wrong wire (it was like black/red vs red/black... somehting of that nature). glad u fixed the prob.
Dyzee
Jun 15, 2004 04:28 PM
boost junky 71
Jun 11, 2004 03:09 AM
B00ST2nR
Apr 18, 2003 03:35 PM
