The Utility In Using a Turbo Blanket: Good or Bad?
Old Feb 21, 2016 | 04:23 PM
bergercurtis's Avatar
Default The Utility In Using a Turbo Blanket: Good or Bad?
Anyone here have recommendations for a good turbo blanket? I'm really thinking it'd be a good idea with how tight my engine bay is in my EF. I plan to wrap the turbo and the downpipe to just before the O2 and wideband bungs.
Old Feb 21, 2016 | 04:27 PM
ls joker's Avatar
Loved
Default re: The Utility In Using a Turbo Blanket: Good or Bad?
dei lava or ptp lava blanket. i have a ptp non lava one from 10 and its starting to crumble apart from being takin on and off so much.
Old Feb 21, 2016 | 04:47 PM
LightningTeg's Avatar
Community Builder
PTP. It's been great but my tial came loose once and the exhaust burned a hole throw the the top.
Old Feb 21, 2016 | 05:13 PM
drmix's Avatar
I have been pretty satisfied with my Thermal Zero brand blanket. Decently priced also.
Old Feb 21, 2016 | 06:30 PM
TheShodan's Avatar
Moderator
I'm a PTP man myself. assembled and stitched better than DEI.
Old Feb 22, 2016 | 04:20 AM
The more and more I look at the build differences (stitching, materials, design), it seems PTP is the way I'm leaning. I used the "lava" material/style wrap on my motorcycle headers and loved the way it looked. I'll likely get the PTP lava and post up some pictures when I get everything together.
Old Feb 22, 2016 | 09:58 AM
LS AzZkIkr's Avatar
Ptp since 07' and I'm finally needing a new one.
Old Feb 22, 2016 | 10:47 AM
KevinEF7's Avatar
The key to having them last is to avoid touching them, take them on and off as little as possible (if a long life matters to you)
Ive even had some lower end ones last a few years, the one Im currently running is from XPS and was only $30 I believe, holding up great
Old Feb 24, 2016 | 02:45 AM
Tony the Tiger's Avatar
Yup, they get brittle after a few months and best is to avoid taking them off, or be very careful when doing so. On some cars, they just get ripped up the moment you remove it.
Old Feb 24, 2016 | 11:39 AM
$amGD3's Avatar
Swaggylicious
and for the love of god wear latex gloves when you're touching these things
i HATE handling wrap/blankets bare handed
Old Feb 24, 2016 | 12:53 PM
Community Builder
Ive taken mine off about 100 times lol. Just be gentle. I like to use compression springs to hold it on, instead of the typical piano wire as well. And if you have a T3 housing, get a T3 blanket. The "T3/T4" is what I have now and it fits loosely over the exhaust housing.
Old Feb 24, 2016 | 12:55 PM
I wrapped my bike exhaust bare handed, but the lava style wrap was brand new and still oiled/flexible. I can imagine getting pricked with a dry, formed piece is like getting poked with fiberglass.
Old Feb 25, 2016 | 09:47 AM
$amGD3's Avatar
Swaggylicious
lol you're fine the first few minutes but then after....your hands start to get itchy...like REALLY itchy,and then it gets worse and it feels like you have tiny shards of fiberglass in your skin
good times
Old Feb 25, 2016 | 11:41 AM
Community Builder
Lava wrap is not nearly as bad, but I would still wear nitrile gloves or something
Old Feb 25, 2016 | 12:18 PM
rudebwoy's Avatar
I have the Dei Lava also, and that **** is falling apart also, paid $200 plus ******* shipping price, needless to say it do the job.
Old Feb 25, 2016 | 12:35 PM
Stopsign32v's Avatar
Loved
good times
Do it enough and your hands get immune to it. Working with BMW parts on the assembly line my hands used to get red as could be and felt like little needles inside my skin. Now it rarely ever bothers me. Every now and then you get one but overall it's not bad.
Old Feb 25, 2016 | 03:48 PM
Community Builder
Did they not give you proper ppe?
Old Feb 25, 2016 | 04:32 PM
Loved
Its optional, Im a manager so I dont do hands on 24/7 just when really needed.
Old Nov 26, 2016 | 04:10 PM
DA 4 Lyfe's Avatar
Do turbo blankets actually keep the temp's lower? I had a PTP before and It didn't do **** for me...
Old Nov 26, 2016 | 09:28 PM
2kdrift's Avatar
Do you have a laser thermometer or thermals camera? these are the only ways to test this other then the hand burn test
the definetly make a big difference, I prefer the titanium versions myself
Old Nov 27, 2016 | 08:17 AM
Flr Power's Avatar
The problem with turbo blanket is that it retains too much heat for road race application and also a bit after engine shutdown.
Best is to use some form of shield to deflect heat from sensitive electronics components...
Old Nov 27, 2016 | 12:26 PM
TheShodan's Avatar
Moderator
I completely disagree. The point is for the turbo blanket to retain as much exigent thermal head as possible, to help with turbine wheel efficiency ( some additional spool characteristics are a by-product of this phenomenon).
The blanket also helps lower ambient temperatures in the engine bay, from additional radient heat. this is not the same as lowering engine coolant temperatures, so forget about looking at your water temp gauge believing it will help you.
This is also separate from actual EGTs that are created from internal engine cylinder temperatures. High knock-resistant fuels , spark plugs, and timing are responsible for that area.
Turbo blankets are honestly an essential part of a balanced breakfast of turbo champions everywhere!
Old Nov 27, 2016 | 12:31 PM
Flr Power's Avatar
I know it can help performance a little bit, I am saying it is harder for the turbo...
Old Nov 27, 2016 | 01:08 PM
B and B's Avatar
Loved
Community Favorite
Old Nov 27, 2016 | 01:54 PM
TheShodan's Avatar
Moderator
No. It's not "harder" on the turbine housing at all, if it's at least a quality turbine housing. I"m still trying to understand where you're getting this information from. I'm not asking for "proof" here, I'm just confused about your speculatory posture. Nothing more.
