URGENT Help Needed. Fresh install problems!!!
Old Sep 21, 2007 | 08:28 PM
TunerShark's Avatar
Default URGENT Help Needed. Fresh install problems!!!
just put my kit on the car, its a 96 EX stock D16Y8, 57 trim turbo, Cast manifold, 3" DP and Test Pipe, front mount, greddy RS BOV etc etc.
the car will not make power at all, i went to my tuner last weekend and he made me a basemap, and this is a reputable shop, not just some random guy who says he can tune hondas, anyways the car will start but it wont make power at all, if i put it in a gear it wont move at all.
its too late to call my tuner, and im supposed to go get it tuned tom sometime so im wondering what you guys think could be causing this?
im running stock injectors in it right now but he said that would be fine to get down to the shop, i have RC 440's that he is supposed to put in when i get there, could this be the problem?
thanks
Old Sep 21, 2007 | 08:32 PM
Dunc's Avatar
BCICAN
Default Re: URGENT Help Needed. Fresh install problems!!! (TunerShark)
What injectors did he make the basemap for? The stockers or the 440's? Define "it won't move at all" a little more. To me "no moving at all" means that you forgot to put your axles back in or something.
Old Sep 21, 2007 | 08:37 PM
TunerShark's Avatar
Default Re: URGENT Help Needed. Fresh install problems!!! (Dunc)
no it will barely just move. maybe at like 1 mph , when its not under load i can rev it up, but when its under load it wont make power, im not sure what injectors he tuned it for, i told him i had stock injectors in right now, but if he tuned the injectors on the map for the 440's would it not make power like its doing now?
thanks
Old Sep 21, 2007 | 09:36 PM
ndogg's Avatar
if you have stock injectors you don't need a basemap, run the stock ecu and DON'T BOOST
Modified by ndogg at 12:59 AM 9/22/2007
Old Sep 23, 2007 | 09:58 AM
Dunc's Avatar
BCICAN
if it was made for 440's then the map wouldn't be so bad that the car wouldn't move at all. Have you check all your electrical connections again?
Old Sep 23, 2007 | 11:15 AM
coneheadsracing's Avatar
What are you using for a computer? Do you have it back to obd I? I'd try the stock computer like was stated, and see what that does, keep it out of boost though.
z0om
Engine Management and Tuning
Apr 5, 2017 05:09 PM
bmbarnum
Apr 13, 2011 05:17 PM
abmerop18
Aug 1, 2005 09:42 AM
The Notorious Frosty
Jan 23, 2004 11:45 PM
turbod16y8
Mar 20, 2003 04:30 PM
