uberdata stutter
Old May 11, 2004 | 03:13 PM
Egone's Avatar
Default uberdata stutter
i finally got my uberdata running right with 450 dsm injectors but the problem is from 2,000rpm to 3,500 rpm the car stutters like its mis firing unless i give it alot of gas what could it be?? im thinking my base maps off could someone check it and perhaps fix it
base maps here... http://www.ecimulti.org/uberda...d=665
Modified by Egone at 5:22 PM 5/11/2004
Old May 11, 2004 | 04:06 PM
MachAF's Avatar
Default Re: uberdata stutter (Egone)
did you change the injector size on the basemap?
you have to find somewhere to host the file. like http://www.we-todd-did-racing.com
Old May 11, 2004 | 04:17 PM
Egone's Avatar
Default Re: uberdata stutter (MachAF)
yep everything runs smooth cept from 2,000 to 3,500 after that runs super mint all way to redline
Old May 11, 2004 | 04:22 PM
Egone's Avatar
link to base map http://www.ecimulti.org/uberda...d=665
Old May 11, 2004 | 04:31 PM
m R g S r's Avatar
Try gettin it tuned, a base map is just that, a base. Tuning should add or take away the right amount of fuel and correct the studdering.
Old May 11, 2004 | 04:35 PM
Mr. Softee's Avatar
Default Re: uberdata stutter (m R g S r)
get it tuned, what hte **** are you driving around on a basemap for
Old May 11, 2004 | 04:37 PM
Egone's Avatar
tuning is coming as soon as i get my wideband but until then i need the car to run smooth
Old May 11, 2004 | 04:44 PM
TorganFM.'s Avatar
Default Re: (Egone)
The only real way to get it to run smooth is to tune it. Until you get your wideband so you can do this I suggest you pull the DSM's out and run stock injectors and not boost.
Old May 11, 2004 | 04:45 PM
Mr. Softee's Avatar
Default Re: (DanW)
yea there is no magical answer.
Old May 11, 2004 | 04:48 PM
Egone's Avatar
hmm alright thanks guys
Old May 11, 2004 | 06:07 PM
J337_UNIT's Avatar
are you getting a CEL by any chance
Old May 11, 2004 | 07:02 PM
Egone's Avatar
Default Re: uberdata stutter (J337_UNIT)
nope no check engine only stutters
Old May 11, 2004 | 07:34 PM
racinskittle's Avatar
what's your setup?
Non vtec I hope
Old May 11, 2004 | 07:55 PM
Egone's Avatar
Default Re: uberdata stutter (racinskittle)
d15b7
14b turbo
dsm 450cc injectors
just using this setup till i save up for a swap
Old May 11, 2004 | 08:05 PM
evosol's Avatar
trim it down 1-2% in the problem area and see if it clears up...
Old May 11, 2004 | 08:07 PM
Mr. Softee's Avatar
Default Re: uberdata stutter (evosol)
1-2% is nothing LOL.
SOHC_MShue's Avatar
hey man i'm running that guy beerbong's maps and I'm having the same exact problem .
Old May 11, 2004 | 09:03 PM
Egone's Avatar
Default Re: uberdata stutter (SOHC_MShue)
can i get his map?? please send to hondaboi8@hotmail.com
Old May 11, 2004 | 09:08 PM
Mr. Softee's Avatar
make your own maps people
Joseph Davis's Avatar
Default Re: (DanW)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DanW &raquo;</TD></TR><TR><TD CLASS="quote">The only real way to get it to run smooth is to tune it.</TD></TR></TABLE>
That's not exactly true, but if you can't figure it out on your own then he has no place trying.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by evosol &raquo;</TD></TR><TR><TD CLASS="quote">trim it down 1-2% in the problem area and see if it clears up...</TD></TR></TABLE>
Quick and sleazy rule of thumb, 10% is about 1 point AFR. Sam's right, a couple tenths won't clear up a too rich/lean condition.
Old May 11, 2004 | 09:57 PM
DIRep972's Avatar
Smarter than you
Default Re: (J. Davis)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by J. Davis &raquo;</TD></TR><TR><TD CLASS="quote">
Quick and sleazy rule of thumb, 10% is about 1 point AFR.</TD></TR></TABLE>
10% changes about 1 point a/f when running what injectors? 450cc?
Old May 11, 2004 | 10:00 PM
warwagon's Avatar
Default Re: (DIRep972)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DIRep972 &raquo;</TD></TR><TR><TD CLASS="quote">
10% changes about 1 point a/f when running what injectors? 450cc?</TD></TR></TABLE>
thats about how mine is going, i used the beerbong map to start with, it was lean at first but i am good now just need to add prolly around 5% at the first few columns of boost and about 5% at the last few columns to achieve around a 11.5-11.8 afr.
Old May 11, 2004 | 10:02 PM
warwagon's Avatar
by the way, it seems that i tried using a base from a p06 and it was terrible, so if you got a wideband i would suggest using the beerbong map, cuz alot say it's smooth as butter, and it is for me!!!!!!
Yeah, 450cc.
Looks like I put my foot in my mouth... thinking about it, that's not strictly true, but for 450cc it is. I've touched too many low buck cars.
Old May 11, 2004 | 10:57 PM
Mr. Softee's Avatar
i agree w/ joseph. for 450s 10% is almost exactly 1 a/f ratio.
