Uberdata datalogging... is this cable ok?
Old Apr 11, 2005 | 09:58 PM
labatt50's Avatar
Default Uberdata datalogging... is this cable ok?
RS-232 Bus-Pin ESD Protection Exceeds
±15 kV Using Human-Body Model (HBM)
Meets or Exceeds the Requirements of
TIA/EIA-232-F and ITU v.28 Standards
Operates With 3V to 5.5V VCC Supply
Operates Up To 250 kbit/s
Two Drivers and Two Receivers
Low Supply Current . . . 300 μA Typical
External Capacitors . . . 4 × 0.1 μF
Accepts 5V Logic Input With 3.3V Supply
Alternative High-Speed Pin-Compatible
RS232 to 3.3V to 5V TTL Serial Converter Cable This converter provides two way RS232 serial communications signal conversion between the TTL (Transistor Transistor Logic) output (from an OOPic or other PIC) to and from a personal computer RS232 serial COM port.
This converter can be used on any Micro controller which has TTL serial communications that needs to be converted to RS232. The cable converts 0v & 5v(3.3v) nominal TTL signal to –12v & 12v RS232 serial signal. This cable require 3.3V to 5V power from the TTL side to operate
here is the link
http://cgi.ebay.ca/ws/eBayISAP...=WD1V
I guess yes but i want a confirmation
thank you
Old Apr 11, 2005 | 10:42 PM
mtber's Avatar
Looks like it will work fine.
I didnt sit down & read every spec... But it is a max3232
Old Apr 12, 2005 | 09:57 AM
labatt50's Avatar
Someone else can confirm?
Old Apr 12, 2005 | 10:04 AM
adseguy's Avatar
Default Re: (labatt50)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by labatt50 &raquo;</TD></TR><TR><TD CLASS="quote">RS232 to 3.3V to 5V TTL Serial Converter Cable
Right there says it all. Yes it'll work. How much is it though, because you can find a USB cable for cheaper (if you have USB ports)
Old Apr 12, 2005 | 01:41 PM
ComputerJLT's Avatar
Default Re: Uberdata datalogging... is this cable ok? (labatt50)
it'll work but i wouldnt buy it
i paid like $9 for a USB cable; it works fantastic
Old Apr 12, 2005 | 01:42 PM
labatt50's Avatar
Default Re: Uberdata datalogging... is this cable ok? (ComputerJLT)
i see the point... the usb make more sense
Old Apr 12, 2005 | 02:06 PM
93turbo16's Avatar
Usb is just a bigger pain in the *** that is all. but for a personal ecu, it isn't hard at all. Just mass production is a pain in the ***.
cua0
May 10, 2007 05:16 PM
corgiat
Nov 22, 2003 08:02 PM
madhatter
Dec 7, 2001 12:52 PM
