two step rev limiter
Old Jan 5, 2003 | 02:47 PM
Lei Siew Long's Avatar
Default two step rev limiter
has anyone hooked the two step rev limiter to a sparco external horn button? if so, how would you compromise the wiring for the turning of the wheel?
if this will not work, i would appreciate other suggestions.
thanks
Old Jan 5, 2003 | 03:43 PM
BudaKai's Avatar
Default Re: two step rev limiter (boostedeg6)
Why don't you just run the wiring through the horn wiring, and move the horn to your dash or something?
Old Jan 5, 2003 | 04:13 PM
Default Re: two step rev limiter (tzsir)
could be a possibility, but, i wanted both to be within reach on the wheel. do others use a reel of some sort if the external horn buttons are actually used for the horn?
Old Jan 5, 2003 | 04:40 PM
SIXTYdashONE's Avatar
HT's Biggest Loser
I used my horn button.. I still retain my horn with the right horn button, and the two step with the left button..its hard tho, u have to use your SRS wiring(airbag), which is sheetwiring, which is very hard to tap and solder, its even hard to explainbut im sure if u took it apart, u would understand, PM me if u need additional help...good luck
Old Jan 6, 2003 | 02:58 PM
Default Re: two step rev limiter (SIXTYdashONE)
any other suggestions?
civicb1812345
Sep 10, 2013 08:28 AM
weavertime1
Jan 11, 2009 12:03 PM
totsie7944
Nov 6, 2007 05:21 AM
TurboTeG4
Aug 16, 2005 11:07 PM
