Two Step
Old Apr 13, 2006 | 08:00 PM
Truman001's Avatar
Default Two Step
Well I am wondering if it would be possible to get rid of my two step. I have crome. It is set for 3000rpm and I am wanting to run slicks.
I do have access to a chip burner, just not sure what I have to do?
Old Apr 13, 2006 | 08:02 PM
itsJDMyo's Avatar
Default Re: Two Step (Truman001)
use the program and you can eliminate it.
Old Apr 13, 2006 | 08:12 PM
Truman001's Avatar
Default Re: Two Step (itsJDMyo)
So just down load it from crome's web site? Sorry I have never tried to tune, or mess with crome.
Old Apr 13, 2006 | 08:26 PM
itsJDMyo's Avatar
you have to use crome-pro, and you can't download it, you have to buy the program.
Old Apr 13, 2006 | 08:50 PM
dornon13's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by itsJDMyo &raquo;</TD></TR><TR><TD CLASS="quote">you have to use crome-pro, and you can't download it, you have to buy the program.</TD></TR></TABLE>
you dont need crome pro for 2step....
Old Apr 13, 2006 | 08:59 PM
Truman001's Avatar
Default Re: Two Step (dornon13)
Well what would I need? Would I just copy my chip, load it in the crome program, and then click the little button for two step off and burn a new chip?
Old Apr 14, 2006 | 05:27 AM
itsJDMyo's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dornon13 &raquo;</TD></TR><TR><TD CLASS="quote">you dont need crome pro for 2step....</TD></TR></TABLE>
of course you don't, but he is already using crome-pro with the 2step option. that is why i told him the only way to get rid of it is to get the crome-pro program and disable that function.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Truman001 &raquo;</TD></TR><TR><TD CLASS="quote">Well what would I need? Would I just copy my chip, load it in the crome program, and then click the little button for two step off and burn a new chip?</TD></TR></TABLE>
you need the crome-pro program, then just somehow load up the program that had on your chip, disable that function, and re-burn the chip
Old Apr 14, 2006 | 05:49 AM
SL0WEGG's Avatar
Where does it say he has crome pro? Dl crome and download the addextrafeatures plug in. disable/change launch control to the same rpm as your rev limiter. save the chip. burn it and your good to go
Old Apr 14, 2006 | 05:53 AM
dornon13's Avatar
Default Re: Two Step (boostedej1)
even if he had it burnt with crome pro i dont think it would matter.
step 1) download crome
step 2)get the burner
step 3) put the chip in the burner and READ the bin on to your computer
step 4) open the bin with crome
step 5) go to the options taba and uncheck the box for 2 step or raise it which ever you like
step 6)save as something new
step7) burn new file to chip
step 8) put it back in car and see if it worked
Old Apr 14, 2006 | 05:56 AM
Truman001's Avatar
Thanks alot for the help! I figured it would be that easy.
Old Apr 14, 2006 | 06:39 AM
ramrod's Avatar
not sure if you do, but if you have all your AC stuff hooked up (atleast under the dash)
you can disable the "2 step" it by turning on the AC switch.
Old Apr 14, 2006 | 06:59 AM
Truman001's Avatar
Default Re: (ramrod)
For real? That would be nice if it worked.
Old Apr 14, 2006 | 07:02 AM
ramrod's Avatar
Default Re: (Truman001)
what i do to make sure its on is i turn my blower fans on, and hit the AC switch and make sure its on, then turn the blower fans back off and at that point the 2 step should be disabled.
try it out and lmk
Old Apr 14, 2006 | 07:05 AM
Truman001's Avatar
I don't have a/c any more, but under the dash stuff should be all hooked up. Thanks for the help I'll try that out after work.
viciousef9
Oct 6, 2007 10:14 PM
SiHater
Oct 26, 2006 01:01 PM
hondachris1994
Mar 2, 2006 12:33 PM
Francesco
Honda S2000
112
Jan 5, 2006 04:22 AM
GreenBean
Apr 13, 2003 01:43 PM
