twin turbo s2000
Old Jul 1, 2007 | 01:15 PM
Murrdog9000's Avatar
Default twin turbo s2000
The 2jz turbo system is one that I am very fond of. I like the fact that it has two turbos, one being smaller than the other and the fact that the small one spools up to give boost then when enough power is about, the small one turns off and the bigger one kicks in. I was wondering if this would be possible for an s2000. If yes, then what modifications would need to be made and what products would or should be used.
Kevin
Old Jul 1, 2007 | 01:31 PM
WalkerGSR1's Avatar
I dont think the smaller turbo turns off it becomes a restriction. Thats why they have single turbo upgrades.
P.S. PUT ON YOUR FLAME SUIT!!! lol
Old Jul 1, 2007 | 01:34 PM
nsxmatt's Avatar
Your talking about a 2.0 4cy vs a 3.0 inline 6. Not to mention the fact Supra owners almost always upgrade to a single.
Old Jul 1, 2007 | 06:03 PM
boostedcivicsir's Avatar
Mr. Badwrench
Default Re: twin turbo s2000 (Murrdog9000)
it could be done, but i think a properly sized single will perform better, unless you are talking huge c.i.d. then a big single will be reaching its back pressure limit. then you need 2.
Old Jul 1, 2007 | 07:43 PM
carchitect's Avatar
My supra has A 2JZ and I'm planning on installing either a GT4202R or (GT3076R X 2).
If I had an S2K instead of my integra I would build and boost the S2K and be happy vs building an S2J. S2J is not a good setup. I'd rather 2JZ another toyota than wander off using a non Toyota chassis.
Old Jul 1, 2007 | 07:46 PM
numbnuts22715's Avatar
loll how can a turbo just turn off
Old Jul 1, 2007 | 07:52 PM
jorge59la's Avatar
Default Re: (numbnuts22715)
single turbos are way better than twins! imo
Old Jul 1, 2007 | 09:24 PM
liam821's Avatar
25 Year Member
Default Re: (jorge59la)
A single gt30r on a s2000 spools extremely quick - you wont have a lag problem and will still be able to put down over 400whp.
liam
Old Jul 2, 2007 | 07:20 AM
PiMpIn's Avatar
Default Re: (liam821)
these guys will do this for you it is awesome
http://youtube.com/watch?v=WirkGXYdOus
http://www.fiftyfiftyracing.com/
Old Jul 2, 2007 | 08:54 AM
rmcdaniels's Avatar
As far as I know, the OEM 2JZ system used two turbos that were the same size. It was sequential in that it worked the waste gates sequentially so that it only spooled one turbo at low RPM, then both at higher RPM (i.e. - it kept the WG open on the second turbo until the RPM was higher).
Old Jul 2, 2007 | 09:12 AM
94civic18's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by numbnuts22715 &raquo;</TD></TR><TR><TD CLASS="quote">loll how can a turbo just turn off</TD></TR></TABLE>
toggle switch... duh!
Old Jul 2, 2007 | 09:34 AM
Default Re: (PiMpIn)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by PiMpIn &raquo;</TD></TR><TR><TD CLASS="quote">these guys will do this for you it is awesome
http://www.fiftyfiftyracing.com/</TD></TR></TABLE>
yahh man ive seen that and its reallll nasty and expensive but i was talkin about just the turbo system
Old Jul 2, 2007 | 09:38 AM
94civic18's Avatar
Default Re: (Murrdog9000)
a lot of people supercharge the S2k's maybe look into that. Basically unless your a foxbody guy stick with a WELL sized single booster
Old Jul 2, 2007 | 09:54 AM
Default Re: (94civic18)
i dont really like superchargers because they dont run off the exhaust
Old Jul 2, 2007 | 09:56 AM
94civic18's Avatar
some people dont like turbos because they run off belts...... if your gunna talk like that, be prepared to be made fun of the HT way..... just warning you.
Old Jul 2, 2007 | 10:01 AM
the ht way?
Old Jul 2, 2007 | 10:09 AM
94civic18's Avatar
the honda-tech way
Old Jul 2, 2007 | 10:20 AM
i like turbos because you can get much more boost out of them....
Old Jul 2, 2007 | 10:23 AM
94civic18's Avatar
thats a little better they should make a crash course on "how not to get flamed on HondaTech"
Old Jul 2, 2007 | 10:34 AM
David_Dc2's Avatar
ull have less lag with a single turbo
Old Jul 2, 2007 | 11:28 AM
blues2k3's Avatar
Default Re: (David_Dc2)
considering the turbo technology out on the market you will be fine with a single turbo on an s2000. I have used many different combination on my s2000 and each have been very responsive.
There was a twin turbo s2000 built some time ago and eventually there was limitiation reached on the power level. I think you need to ask yourself what are you using the car for and what kind of power are you looking for, times you want to run and most inportantly how much is in you pocket...
Old Jul 2, 2007 | 11:45 AM
integraRS-T's Avatar
Default Re: (blues2k3)
nice setup might wanna put a grill or air filter garret's are notorius for eatin things
Old Jul 2, 2007 | 12:28 PM
liam821's Avatar
25 Year Member
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 94civic18 &raquo;</TD></TR><TR><TD CLASS="quote">a lot of people supercharge the S2k's maybe look into that. Basically unless your a foxbody guy stick with a WELL sized single booster </TD></TR></TABLE>
You'll get a better powerband with a correctly sized turbo then most of the superchargers out there. Why? because they are all centrifugal superchargers and make no boost until 6000rpms because the s2k motor spins so high they have to gear them WAY down so they dont over boost at high rpms.
Totally useless peaky powerbands. If i wasnt so lazy id post dyno plots of both but you can search yourself for that.
liam
Old Jul 2, 2007 | 12:54 PM
rmcdaniels's Avatar
Lovefab's single turbo S2000:
Old Jul 2, 2007 | 02:15 PM
boosted timebomb's Avatar
Default Re: (rmcdaniels)
didnt the 3rd gen RX-7s come with a twin turbo system with one small and one big turbo? if you really wanna do a twin setup you can go on ebay and find them everywhere.
