Twin Scroll...hype or not? S2000 Comparison
Old Jun 15, 2009 | 04:46 PM
AFI Turbo's Avatar
Default Twin Scroll...hype or not? S2000 Comparison
Car is a AP1 S2000
Laskey bottom end
Portflow head
AEM EMS (Tuned by UMS Tuning)
GT4094R turbocharger
Hypertune Intake Manifold
***Changes made***
Swap open sidewinder style manifold to AFI Twin scroll manifold
Swap .85ar Divided housing to 1.06ar Divided housing
Boost Plot
***Dark Blue is AFI Setup***
Graphs
Look at the midrange gains
Old Jun 15, 2009 | 04:49 PM
m R g S r's Avatar
Default Re: Twin Scroll...hype or not? S2000 Comparison
So it was a non divided manifold with a divided .85ar housing turbo first
then switched to a different divided manifold with divided 1.06ar housing?
Any pics of the two manifolds to compare?
Old Jun 15, 2009 | 04:57 PM
AFI Turbo's Avatar
Yes that is correct, switched to a divided manifold and larger 1.06 housing.
I don't have any pics of the old manifold, just the new one.
Old Jun 15, 2009 | 04:59 PM
marcj's Avatar
WHY did you swap the housings? that made your comparison null and void.. that's like comparing two separate turbos with different manifold combinations..
For all we know, the smaller housing was a choking point, and the gains were from that, not your divided pulse manifold.
Old Jun 15, 2009 | 05:16 PM
AFI Turbo's Avatar
The housing was swapped because my job was to provide my customer with a "better" setup than he previously had. I'm posting this comparison because quite frankly the difference is very clear.
I could care less about the peak numbers, its obvious that the new setup is running less boost anyways (~2psi should be another 40whp easily)
Lets say a 1.06 on the the open manifold does make the same peak as the new manifold (at similar boost pressure) What do you think the midrange will look like then?
Old Jun 15, 2009 | 05:20 PM
Muckman's Avatar
Moderator in Chief
I think this is confusing the way its worded.
Setup1: Open sidewinder style manifold with .85ar Divided housing
Setup2: AFI Twin scroll manifold with 1.06ar Divided housing
Setup2 with larger AR spools 800rpm faster
Setup2 makes about the same power as setup1 but with less boost. But power is harder to compare bc of the AR change.
Old Jun 15, 2009 | 05:51 PM
Ryank327's Avatar
I agree that it would have been more accurate without swapping housings but it is obvious to see the large Mid-range gains and the 800pm faster spool and that faster spool is with a larger housing at that.
That's enough to make me dish out the money for a Twin scroll and divided manifold
Old Jun 15, 2009 | 06:24 PM
96 GSR-T's Avatar
I dont think its hype at all, I have a friend that insists on running divided turbo's on undivided manifolds and I think its just plain stupid, he had a 42R on an undivided manifold he sold that and is now planning on running a 40R on an open scroll.
I dont see how this is null and void, he went from a smaller faster spooling housing on an undivided setup to a larger slower spooling housing on a matching divided setup and reached full boost over 500rpm quicker.....
Old Jun 15, 2009 | 07:07 PM
EARLdaSQUIRREL's Avatar
official honda whore
definetly shows the potential, wasnt there a graph somewhere showing a 30r with a divided housing?
Old Jun 15, 2009 | 07:39 PM
AFI Turbo's Avatar
We have a divided 30r on our Time Attack S2000. Peak tq (~380ftlb's) @ 3700-3800rpms
Old Jun 16, 2009 | 05:22 AM
tepid1's Avatar
I think everyone is missing the point here....
One would expect the larger A/R to spool later, correct? When in fact with the manifold being true divided (not actually twin-scroll) is spooling faster even with the larger A/R.
I say job well done AFI!
Old Jun 16, 2009 | 05:46 AM
Tjabo's Avatar
This is AWESOME information, thanks for sharing! ! ! !
Old Jun 16, 2009 | 07:12 AM
nos51's Avatar
good **** from afi like always!!i love my intake manifold from afi for my k,makes me proud everytime i open the hood!!
Old Jun 16, 2009 | 10:06 AM
AFI Turbo's Avatar
Old Jun 16, 2009 | 10:08 AM
MAperformance's Avatar
Great comparison guys!
Would love to get one of your twin scrolls on our S2000!
Old Jun 16, 2009 | 10:48 AM
Tjabo's Avatar
One thing guys (OP), what exhaust was in use with each of these setups? I'm assuming it was the same, but I'm still curious what it was. . .
Note: That early of a spool on a 4094 being spun by a 2 liter is pretty amazing, isn't it?
Old Jun 16, 2009 | 10:56 AM
AFI Turbo's Avatar
Exhaust remained the same.
The downpipe did change...however the length and number of bends remains very similar.
Old Jun 16, 2009 | 10:57 AM
AFI Turbo's Avatar
I'm sure we can work something out
Old Jun 16, 2009 | 11:04 AM
Tjabo's Avatar
Are you willing to disclose what it consists of?
Old Jun 16, 2009 | 11:24 AM
AFI Turbo's Avatar
I'm honestly not sure what brand it is maybe Greddy? It was on the customer's car previously...Standard 3"
The downpipe like mentioned above is very similar...has an extra 90 deg bend over the previous setup. New Downpipe is pictured:
AFI Turbo
Aug 11, 2011 11:34 AM
FEDDC
Honda S2000
Sep 9, 2009 01:31 PM
prospeed
Mar 8, 2002 10:02 PM
