Twin-disc users reply?
Old Dec 7, 2002 | 11:58 AM
Speedworks801's Avatar
Default Twin-disc users reply?
Anyone using twin-disc setups please comment on what you have and make suggestions please.
Thanks in advance.
Old Dec 7, 2002 | 12:08 PM
MotorMatrix.com's Avatar
I am a bad person
Default Re: Twin-disc users reply? (Speedworks801)
i have the clutchmaster double disc w/ sintered iron pads. i love it!! the clutch is as soft as stock but grabs like a bitch. So far its been good to 750hp. Also the lightened flywheel helps it rev up quickly.
[Modified by MotorMatrix.com, 5:45 PM 12/7/2002]
Old Dec 7, 2002 | 01:24 PM
ekb18c's Avatar
for the street? It's a overkill.
Old Dec 7, 2002 | 01:34 PM
I am a bad person
Default Re: Twin-disc users reply? (ekb18c)
so is the 570hp I'm pushing but anything else slips. And guess what you wont break your leg working the clutch in and out of traffic
[Modified by MotorMatrix.com, 5:35 PM 12/7/2002]
Old Dec 7, 2002 | 01:39 PM
boosted3g's Avatar
Default Re: Twin-disc users reply? (MotorMatrix.com)
What is the retail on the twin disk I need a clutch
Old Dec 7, 2002 | 01:42 PM
THERE IS NO SUCH THING AS OVERKILL EKB18C!
Any experience with the Exedy setup?
[Modified by Speedworks801, 4:43 PM 12/7/2002]
Old Dec 7, 2002 | 01:45 PM
I am a bad person
Old Dec 7, 2002 | 01:46 PM
I am a bad person
guess you caught the above comment. the pedal is as soft as stock
Old Dec 7, 2002 | 02:01 PM
D-Man's Avatar
Call clutchmasters,they dont recommend thier twin disc for a daily driver(if thats what your building,if its a race car,ignore this post ),they say itll wear out pretty quick.
Old Dec 7, 2002 | 02:05 PM
Default Re: Twin-disc users reply? (D-Man)
Naysayers need not respond.
Thanks.
Old Dec 7, 2002 | 02:06 PM
I am a bad person
All you have to do is have it re-pucked or replace just the clutch plates not the whole assembly. I would rather run the DD clutch then break my leg on a double diaphragm clutch. Also, you dont get the chatter leaving every stop light.
Thanks for the reply MotorMatrix.
Old Dec 7, 2002 | 02:13 PM
D-Man's Avatar
Thanks.
Naysayer!?! only passing on info that came direct from the maker and u give me a thumb down for tryin to help out..fucc u
Old Dec 7, 2002 | 02:14 PM
boosted3g's Avatar
So does anyone remember what they paid for theirs.
Old Dec 7, 2002 | 02:15 PM
NO time for your ego. Sorry. Lick your wounds elswhere.
Old Dec 7, 2002 | 02:18 PM
Default Re: Twin-disc users reply? (boosted3g)
So far I'm getting quotes for around $1300.
Old Dec 7, 2002 | 03:40 PM
ekb18c's Avatar
Dude, there's no need to yell. You ask for an opinion I tell you my opinion. If you didn't want my opinion then why ask?
And there is such a thing as overkill for the street.
FYI -- The CM twin disk is not recommended for street use because of it's short life span. You can call Luis up @ CM and he'll tell you the same damm thing! Or you can call Chris @ CM and he'll tell ya!
Old Dec 7, 2002 | 06:27 PM
jinxproof99's Avatar
New User
i had the twin disc(clutchmasters) in my car for almost a year. ran over 100 passes at the track and drove it 2-3 times a week on the street. worked fine. clutchmasters doesn't recommend them for the street, but if your not using it ALL THE TIME or in heavy traffic alot, i think it works great. holds ALL OF THE POWER!!!!
Old Dec 7, 2002 | 09:35 PM
C-Murdock's Avatar
Default Re: Twin-disc users reply? (jinxproof99)
who makes a twin disc for an h22...it includes flywheel as well ?
Old Dec 7, 2002 | 09:48 PM
ekb18c's Avatar
Default Re: Twin-disc users reply? (C-Redrum)
ATS makes one and I'm sure you can get a os giken or tilton.
Old Dec 7, 2002 | 10:39 PM
I am a bad person
tilton makes one that is double disc and it comes with a 6lb flywheel
Old Dec 8, 2002 | 12:09 AM
TurboITR's Avatar
tilton
pretty soft pedal feel - neck snapping grip...
Old Dec 8, 2002 | 06:05 AM
C-Murdock's Avatar
Default Re: Twin-disc users reply? (TurboITR)
where can i find out more about this Tilton clutch for my h22 ?
Old Dec 8, 2002 | 11:22 AM
I am a bad person
http://www.tiltonengineering.com
I an get you one when you are ready to buy it. ill hook you with a gangster price.
