TurboXs Boost Contorllers
Old Feb 5, 2004 | 01:54 PM
Austinbionic316's Avatar
Default TurboXs Boost Contorllers
Is it safe to use the Dual Boost Controller on a FMAX turbocharged GSR motor? and if anyone was one is it true u gain like 10-20hp with the Dual boost controller?
Old Feb 5, 2004 | 02:24 PM
kaj's Avatar
kaj
Default Re: TurboXs Boost Contorllers (Austinbionic316)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Austinbionic316 &raquo;</TD></TR><TR><TD CLASS="quote">Is it safe to use the Dual Boost Controller on a FMAX turbocharged GSR motor? and if anyone was one is it true u gain like 10-20hp with the Dual boost controller?</TD></TR></TABLE>
WTF??
i feel guilty for even responding.
Old Feb 5, 2004 | 02:35 PM
b18b1hmtlove's Avatar
dual boost controller will not atribute to a gain in power, what gives you the gain in power is the capability of having 2 boost limits selected.
EX: stage one may be 8psi and stage two may be 15psi. That jump would be much more than just 10-20whp. from your signature i see that your car seems to be completely built so something like this might allow you to drive daily and have a 300hp street car and then change to a different stage and that setting will be 15psi and you will be near 400whp(???)
Old Feb 5, 2004 | 03:04 PM
JGurr81's Avatar
Default Re: (b18b1hmtlove)
True but the boost controller itself does not give you the horsepower! It will help increase spool times by leaving the waste gate shut until the right psi is reached, then the wastegate opens, so there is no bleeding off boost! Make sure you get a ball and spring, and not a "bleeder" type boost controller, which the TXS DS BC is( haha sorry for the abbr. ) dont know about the Stage 1 though?
Old Feb 5, 2004 | 03:07 PM
yeah the motor is built and I was just wondering that's all, thanks for the information
Old Feb 5, 2004 | 09:45 PM
civicshowracing65's Avatar
i just installed the turboxs dual stage boost controller 2 weeks ago. So far it is working good with no boost spikes. The only thing is the difference between night and day. During the day, my second stage is set at +.59kpa. At night due to the colder weather it goes up to +.67kpa. Just fyi
Old Feb 6, 2004 | 12:05 AM
TravSi's Avatar
Default Re: TurboXs Boost Contorllers (kaj)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by kaj &raquo;</TD></TR><TR><TD CLASS="quote">
WTF??
i feel guilty for even responding.</TD></TR></TABLE>
HAHAHA
FRernesto
Sep 15, 2007 06:51 PM
wezzel19
Aug 7, 2006 08:19 PM
red cx
Aug 18, 2005 02:19 AM
15psi of fun
May 12, 2004 07:00 AM
ATS*Mark
Aug 19, 2003 05:35 AM
