turboing the b16
Old Jun 13, 2005 | 11:26 AM
Civicvtihatch's Avatar
Default turboing the b16
I just bought a turbo kit from a buddy of mine! for my 99 si coupe
consists of t3/t4 turbo ram horn manifold, front mount intercooler...and basically everything you need.
But i was wondering what injectors i should buy(size)? Fuel pump?
can i run an obd 2 to obd1 conversion harness with a chipped p28(chrome professional)program?
Old Jun 13, 2005 | 11:43 AM
BlueShadow's Avatar
Default Re: turboing the b16 (Civicvtihatch)
-injectors size...that depends on your power goals. How much you planning on making?
-it's always a good idea to upgreade the fuel pump. It's only $79-$99 for a 190-255lph so might as well.
-to be able to run CromePRO which is only for OBD 1, all you would need is an OBD 2 to OBD 1 ECU conversion harness and of course a chipped and socketed OBD 1 ECU like a 92-95 P28.
Old Jun 13, 2005 | 11:50 AM
Default Re: turboing the b16 (BlueShadow)
Thanks for the info! Im only planning on running 8-10 psi daily!
Old Jun 13, 2005 | 12:20 PM
BlueShadow's Avatar
8-10 PSI would probably be around 275-350 WHP on that turbo. 550cc's would for around 325-350ish HP, and 650cc's for about 380-400ish HP.
Old Jun 13, 2005 | 08:28 PM
so between 370 and 440 cc injectors?
Old Jun 13, 2005 | 08:53 PM
Bailhatch's Avatar
Default Re: (Civicvtihatch)
no, get 650s minimum. Im using 880s on my B16 so i wont have to buy bigger ones later.
scia220
Feb 3, 2011 04:44 PM
360Deezy
Northwest (Sales)
Nov 2, 2010 08:59 AM
ej1serge
Jun 9, 2008 06:24 PM
ej1serge
Jun 8, 2008 05:09 PM
hotimportcrx
Jul 14, 2005 05:09 PM
