Turbocharged 00 ITR
Old Feb 17, 2003 | 12:49 PM
ITR00-1200
Guest
Posts: n/a
Default Turbocharged 00 ITR
I'm pretty sure you get this a lot, but I've made up my mind to go FI on my ITR. What would be the best kit to go for is my question. I know Top Fuel has good kits and so does Apexi. Revhard and drag.. not sure.. but does anyone have any good experience with any of these? Custom? I'm leaning towards an HKSGT2530 or the 2835 turbine.. but I still have my options open. Let me know if you guys have had a lot of experience, I just want to make it right the first time. Thanks.
Old Feb 17, 2003 | 01:07 PM
92JDMSiR's Avatar
Default Re: Turbocharged 00 ITR (ITR00-1200)
your going to have to be more specific. what is your horsepower goal? is this car daily driven? will you be using the stock block? will you be using some sort of engine management? you can't just say "ok guys I'm going over to the darkside" you have to have a goal. and most important, use the search next time for a question like this. this has been covered many many times before.
Old Feb 17, 2003 | 01:56 PM
MiraiZ's Avatar
Top Fuel is overpriced!
Old Feb 17, 2003 | 02:09 PM
vtec.dc2's Avatar
be more specific.. what you want to do? how much hp/psi to run? top end or mid-high? price range?
Old Feb 17, 2003 | 02:16 PM
PM-Performance's Avatar
Default Re: Turbocharged 00 ITR (vtec.dc2)
Be more specific, do a search becuase this was covered like 957 times
Oh yea and why would you wann turbo a Type R , it supposed to stay Na , dont you know that by now?
Old Feb 17, 2003 | 02:26 PM
vtec.dc2's Avatar
Default Re: Turbocharged 00 ITR (itr206)
true... type r is only for all motor
[Modified by vtec.dc2, 6:27 PM 2/17/2003]
Old Feb 17, 2003 | 02:47 PM
Finland's Avatar
My 2000 ITR has been turboed for 2years. Running a RevHard stage 3 setup. Plus some extras. Runs a 13.6 at 107mph with stock factory original tires, 60ft 2.095.
If you want other details specifically, let me know.
Old Feb 17, 2003 | 02:50 PM
vtec.dc2's Avatar
Default Re: Turbocharged 00 ITR (acurate1)
anymore details on turbocharger of that setup and how much boost?
Old Feb 17, 2003 | 03:25 PM
NCSTIdriver's Avatar
a turbo type r pulling a 13.6 that seems kinda low. I did that in my Jrsc'd lude. how much psi were you pushing mine was at 6 on stock tires. but your trap speed was higher than mine.
Old Feb 17, 2003 | 03:32 PM
evoeone's Avatar
Default Re: Turbocharged 00 ITR (NCH22driver)
piece a kit, thats the only way you get every compnoent you want, i hate "kits" theres always a part that you dont want
Old Feb 17, 2003 | 03:49 PM
SpeedRacer00-667's Avatar
Default Re: Turbocharged 00 ITR (evoeone)
drag or rev hard is a good start
Old Feb 17, 2003 | 03:55 PM
Cyber ITR's Avatar
Default Re: Turbocharged 00 ITR (SpeedRacer00-667)
go with HKS GT3240
Old Feb 17, 2003 | 06:56 PM
Finland's Avatar
You're right, 13.6 wasn't all that good. As the trap speed indicates, I am experiencing violent wheel spin that doesn't subside until 3rd gear. On one of my 13.8 runs my mph was 109. I think this season with drag radials and Z10, I may hit high 12's. Oh, I also added 440cc injectors, we'll see how it goes.
Old Feb 17, 2003 | 07:00 PM
Finland's Avatar
Turbonetics T3/TO4E-60 trim. I usually run 7 to 9 psi. I have 22000 miles on the turbo, no problems. Stock timing. Just have to have self control with the boost, she will detonate at 10 psi (stock timing)
Old Feb 19, 2003 | 03:12 AM
ITR00-1200
Guest
Posts: n/a
Didn't mean to make it sound so broad. I want to get a kit that has the best average power in the mid 4-5500 area and is best tunable for a wide torque band instead of peak. Not double my output, but in the 260-280 hp range. It has to at least be driveable on the street. I've ran in mostly autox events, but I also run 1/4 mile everyone now and then. My car has about 18k on the motor. As far as extras, I was planning to go with a power fc, cams, adj. cam gears, bigger injectors, etc.. using my stock block also. Haven't had much experience with turbo's, but this is my ideal goal. Don't want to go over the 4.5k price range so this is all I have to work with. What are your setups, hp, tq, 1/4s? What are your ideas or options you would do? I just need to broaden my horizon on what I'm looking at, going to the "darkside." All of your help will be greatly appreciated, like I said I just want to get it right the first time.
Old Feb 19, 2003 | 05:03 AM
01ITR#700's Avatar
Agreed.
M
Old Feb 19, 2003 | 08:41 AM
vtec.dc2's Avatar
although any turbokit will get you the hp range - and you dont need cam gears, you'd need 440's injectors.
i'd say T3 super60. i got T3/T4b S3 (50trim) .48 a/r - i plan to run 4.35-5psi boost and whatever comes out of it.. you could probably achieve your goal at 6-8psi. If possible, invest in a better manifold - with any kit you'd want external wastegate. maybe T3 60 trim - and if you want to help with spool - get ball bearing.
- check out compression maps - you could decide for yourself - there are topics. whatever you choose, you'd want something that spools fast if you want quick response at low rpm.
Old Feb 19, 2003 | 09:43 AM
b18cya's Avatar
who says ITR's shouldn't be turbocharged?
Old Feb 19, 2003 | 10:30 AM
Default Re: Turbocharged 00 ITR (b18cya)
I say they shouldnt , you gonna prove me wrong
yea if you dont plan on boosting much thne not ness to get something too big, but you need to get soemthing that will be able to handle the high RPm's . remember the R revs high, dont get something that will give up at 8k or something like that , but you want something that will spool quicker since you dont plan on giving it big time boost
i dunno man , its a pain sometimes, i feel just go all out , fuggit 400 hp street demon
Old Feb 19, 2003 | 10:52 AM
Type-ARR's Avatar
I do, they were built for all-motor not turbo...
Old Feb 19, 2003 | 06:54 PM
vtec.dc2's Avatar
Default Re: Turbocharged 00 ITR (Type-ARR)
type arrrr is too good for turbo...
Old Feb 19, 2003 | 06:55 PM
MiraiZ's Avatar
Yeah!! ITR's perform the best and get better power when completely stock
Old Feb 19, 2003 | 08:53 PM
b18cya's Avatar
Default Re: Turbocharged 00 ITR (MiraiZ)
or you could bolt on a turbo & get 282 whp untuned (aka: Pig-rich) at 5800' ft altitude.
mark...where are you??
[Modified by b18cya, 10:54 PM 2/19/2003]
DAinfamousR
Feb 14, 2007 01:55 PM
sARCASTiC
Apr 18, 2005 08:51 PM
beavt8r
Jun 28, 2004 04:25 PM
ChiNoS
May 9, 2003 08:25 PM
TwnPimp3
Oct 4, 2002 06:14 AM
