Turbo z6
Old Jan 30, 2002 | 10:24 PM
ImportHatch's Avatar
Default Turbo z6
Hey Im piecing together a turbo for my z6 in my crx and had a few questions. I am only planning on running about 6 psi. I am going to be using a T-25 with the HF manifold and custom adapter plate and something like a starion intercooler. . My question is about fuel. Should I get a a/f gauge and should I get a fuel pressure regulator so I can make sure its gettin the right mix? Any info on this would help me out. Thanks in advance.
Yager-
Old Jan 31, 2002 | 08:26 AM
DLB1994's Avatar
Default Re: Turbo z6 (ImportHatch)
yeh get a air-fuel and get a vortech fmu with a 12:1 rise rate and a inline fuel pump and that about do it
Old Jan 31, 2002 | 08:30 AM
VTC_CiViC's Avatar
Default Re: Turbo z6 (DLB1994)
A/F gauge
EGT gauge
Old Jan 31, 2002 | 10:51 AM
Pritos's Avatar
New User
a/f and regulator should get you off and boosting.... if you start to run lean then up the fuel pressure. if you have more money to blow then an egt will help you out too.
And I believe now that there is no CHEAP egt. either buy an expensive one or none at all.
JuicedUpRice
Nov 12, 2012 09:00 AM
Mr. Em1
Jun 21, 2009 04:20 PM
sneakypete
Aug 29, 2003 02:14 AM
HybridCoupe
Jul 11, 2002 12:38 AM
not so civic
Aug 12, 2001 02:27 PM
