Turbo Weather
Old Apr 30, 2003 | 09:46 AM
yimmy's Avatar
Default Turbo Weather
I have wondered this for awhile. Will the weather dramtically affect a turbo car. Im asking because my integra has never been driven below about 80 degree weather and during this winter on a nice day I took it out when it was about 40. The car did not pull hard at all and just seemed like a dog. I am hoping that is the reason why but im not sure.
Old Apr 30, 2003 | 09:51 AM
done's Avatar
Default Re: Turbo Weather (yimmy)
cooler weather makes it run alot smoother...
The oxgyen molecues are bunched up more, when its colder...
Old Apr 30, 2003 | 10:06 AM
*Boostwerks*'s Avatar
It will especially if it's IC'd.
You should notice a little more power at lower temperatures.
Old Apr 30, 2003 | 11:05 AM
Hybrid Invasion's Avatar
Default Re: Turbo Weather (Bryson)
even NA cars perform better when it's cooler outside because it's kicking cooler air into the engine. That's just a known fact. That's why there's Cold Air Intakes, sir
Old Apr 30, 2003 | 11:08 AM
boostin b16's Avatar
Default Re: Turbo Weather (Hybrid Invasion)
your car will run a little leaner in the cold, but it shouild be a noticable amount quicker!
Old Apr 30, 2003 | 11:09 AM
Teg4e's Avatar
My car feels quite a bit faster in the cold weather. I figured out first that in 20 degrees, the tires aren't gonna grip as well, making for more wheelspin and fooling me into thinking my motor's more powerful. But also i get about 9psi max boost in 20 degree weather and only 8 or 8.5 psi in 80 degree. One more thing, you're probably gonna be using a/c in the hot weather, losing you some hp as well.
Old Apr 30, 2003 | 11:10 AM
Slick GS-R's Avatar
the bottom line is that any car will run better in the colder weather because there is more oxygen!
Old Apr 30, 2003 | 11:47 AM
BoostedsiR's Avatar
Default Re: Turbo Weather (Slick_GS-R)
up north in the fall is the best time harley any humidity and it is about 50 degrees
cool dense dry air is when turbos scream you should notice a slight difference in boost and the way the car idles
Old Apr 30, 2003 | 12:30 PM
yimmy's Avatar
Default Re: Turbo Weather (BoostedsiR)
Thanks for the imput. It must just be my car then. It was definetly not pulling like it should of been.
Old Apr 30, 2003 | 12:39 PM
Tinker219's Avatar
probably TOO lean. Colder air means more o2 molecules, which offsets the air/fuel ratio. Turn up the fuel next time you go out
Old Apr 30, 2003 | 06:55 PM
MiraiZ's Avatar
Default Re: Turbo Weather (Tinker219)
This leads me to another question....
These standalones that we use, use static fuel maps...when I say static, I mean that they don't change accordingly with the ambient temperature changes. Is there a standalone that does compensate for the delta in ambient temperatures?
Old Apr 30, 2003 | 07:18 PM
danl's Avatar
Banned
Default Re: Turbo Weather (MiraiZ)
HOndata should revert to the factory honda temp sensor and add a little fuel with weather changes. Still, the changes won't be perfect due to the drastic changes in the motor.
My duty cycles usually go up 1 percent for every 10 degree drop in intake temps.
Old Apr 30, 2003 | 08:51 PM
blown_LS's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Hybrid Invasion &raquo;</TD></TR><TR><TD CLASS="quote">even NA cars perform better when it's cooler outside because it's kicking cooler air into the engine. That's just a known fact. That's why there's Cold Air Intakes, sir </TD></TR></TABLE>
Exactlly !!! My car runs lot better in cooler weather.
Old Apr 30, 2003 | 08:58 PM
MachAF's Avatar
Default Re: Turbo Weather (boostin b16)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by boostin b16 &raquo;</TD></TR><TR><TD CLASS="quote">your car will run a little leaner in the cold, but it shouild be a noticable amount quicker! </TD></TR></TABLE>
you mean it will run richer when its cold. hence why I get terrible gas mileage in -10 degree winters.
Old Apr 30, 2003 | 11:36 PM
MiraiZ's Avatar
Default Re: Turbo Weather (MachAF)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by MachAF &raquo;</TD></TR><TR><TD CLASS="quote">
you mean it will run richer when its cold. hence why I get terrible gas mileage in -10 degree winters.</TD></TR></TABLE>
Leaner is correct.. denser air molecules = more air = higher air to fuel ratio = leaner conditions
Hiboost 2.0
Sep 18, 2011 06:26 AM
ShaneTS409
Nov 26, 2008 11:10 PM
Sleek98
Jun 17, 2003 09:21 AM
311
Jul 6, 2002 04:22 PM
fiebru1119
Apr 18, 2002 08:13 PM
