turbo tuning
Old Nov 28, 2006 | 10:19 AM
jrs2ksi's Avatar
Default turbo tuning
I'm putting a turbo on my civic in the near future. What needs to be done after i install everything (tuning wise?)
thanks.
Old Nov 28, 2006 | 10:21 AM
Schister66's Avatar
Man U FTW
you're going to need an OBD2b to OBD1 conversion harness, a chipped P28, and a tuning software.....then you're going to need someone to tune it....what does your setup look like so far??
Old Nov 28, 2006 | 10:22 AM
jrs2ksi's Avatar
Default Re: (Schister66)
where can i get that stuff?
Old Nov 28, 2006 | 10:23 AM
BoostedEG6's Avatar
Default Re: turbo tuning (jrs2ksi)
How far are you from SD area? Look up Importbuilders.com for Hondata, ECU and tuning and I also recommend LOCASH for conversion harness
Old Nov 28, 2006 | 10:25 AM
jrs2ksi's Avatar
Default Re: turbo tuning (BoostedEG6)
about 3 1/2 hours
Old Nov 28, 2006 | 10:31 AM
BoostedEG6's Avatar
I want to say he is around the LA area or SD area… Go to his site importbuilders.com and check with him to see where he is located.... I cant remember which though, But I highly recommend him to anyone who wants to tune with Hondata in that area.. he is defiantly worth the drive... we flew him out to Hawaii to tune around 15 cars for us that where all on Hondata back in 03-04
Also Jerry Built is another place to look into for tuning
Old Nov 28, 2006 | 10:34 AM
jrs2ksi's Avatar
what exactly does a OBD2b to OBD1 do?
Old Nov 28, 2006 | 10:54 AM
jrs2ksi's Avatar
so i couldn't drive my car at all without it tuned? Not even to my tuner's shop?
Old Nov 28, 2006 | 11:06 AM
aaronISthrowed's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jrs2ksi &raquo;</TD></TR><TR><TD CLASS="quote">so i couldn't drive my car at all without it tuned? Not even to my tuner's shop?</TD></TR></TABLE>
You can, just keep the stock injectors in and the ecu the car came with. DONT go into boost. Oh and take out the spring in the wastegate so you dont build boost.
Old Nov 28, 2006 | 11:07 AM
Schister66's Avatar
Man U FTW
if you know your setup, then you can tell the person who is chipping your ECU to put a basemap on it for you so that you can drive to get tuned....
http://www.j-k-tuning.com
Old Nov 28, 2006 | 11:13 AM
jrs2ksi's Avatar
so i cant buy one thats already chipped?
Old Nov 28, 2006 | 11:14 AM
jrs2ksi's Avatar
Default Re: (jrs2ksi)
like this
http://www.j-k-tuning.com/chip....html
Old Nov 28, 2006 | 11:33 AM
Schister66's Avatar
Man U FTW
^^thats what i bought.....
Old Nov 28, 2006 | 11:37 AM
jrs2ksi's Avatar
but u still have to take it to get it tuned, right?
Old Nov 29, 2006 | 06:24 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jrs2ksi &raquo;</TD></TR><TR><TD CLASS="quote">but u still have to take it to get it tuned, right?</TD></TR></TABLE>
Yeah, the basemap is only used so you can drive around and get to the tuner. DONT boost on the basemap
Old Nov 29, 2006 | 06:30 AM
BoostedEG6's Avatar
Default Re: (aaronISthrowed)
A base map is a base for tuning, it simply works for you to start your car and check for leaks and so on (it is pretty much a guess on allot of things. Just because its tuned for one persons car does not mean it will be the right tune for you. Every motor is different and there are allot of variables that can be different).....
I do not recommend for anyone to drive around on one due to not knowing what your a/f ratio is and you run the chance of washing out your cylinders with to much fuel..... I will tell you like I tell everyone
1. Start your car to check for CEL's, oil leaks, coolant leaks and vac leaks
2. Put your car on a trailer or get it towed to who ever is tuning
3. Put the car on the dyno and tune
4. take the car out to do a street tune for driving conditions
5. Enjoy boost and dont worry about anything that "could" go wrong because of you being on a base map
FW_EJ8
Sep 15, 2007 01:36 PM
RudeBwaiSi
Sep 9, 2005 07:07 AM
B18B1DOHC
Feb 20, 2004 10:12 AM
crx1856
Aug 26, 2003 10:16 PM
platinum00
Aug 19, 2003 04:29 AM
