Is this turbo too small?
Old Apr 4, 2006 | 12:55 PM
mozzandherb's Avatar
Honda-Tech Titanium Member
Default Is this turbo too small?
With the h22 stock internals looking to run at 8lbs of boost at first then build up the motor in the future, but is this turbo too small, should I be looking for a bigger one.
It's a a/r .48 and a v trim t04b compressor? Thanks
Old Apr 4, 2006 | 01:48 PM
rsintegra's Avatar
Default Re: Is this turbo too small? (mozzandherb)
What are your goals? The V trim, I believe, is the largest of the t04b family, and will spool fairly quickly with an h22. However, with an A/R of 0.48, your top end will be limited. Personally, I think the turbo is a tad small, especially if you're looking to build up your motor and boosting more. If you already have the turbo, try it out and see if you're satisfied with it before switching out to something larger.
ludekid4323
Dec 6, 2006 11:57 AM
huge230
Feb 6, 2006 04:28 PM
99blackvti
Jun 28, 2005 08:25 PM
Nytmair
Sep 14, 2004 10:49 AM
Non-Vtec101
Oct 20, 2003 12:18 PM
