Turbo Timer install help 99-00 Si
Old Jan 26, 2006 | 11:11 AM
jeffk182's Avatar
Default Turbo Timer install help 99-00 Si
I have what I think is a HKS Type 0 turbo timer, but I have no idea where this 1 wire goes because I got it used. Pics:
I dont know where the brown wire goes. Im refering to the picture with the ignition column wiring thats been widley used and I foun out how to wire the green, blue, and red. I know that the gray is for the parking brake, black is ground. I just have no idea where the brown wire goes. Thanks.
Old Jan 26, 2006 | 11:22 AM
beerbongskickass's Avatar
Default Re: Turbo Timer install help 99-00 Si (jeffk182)
Turbo timers are for pansy's and fairy's...
Old Jan 26, 2006 | 11:47 AM
sicones's Avatar
Default Re: Turbo Timer install help 99-00 Si (beerbongskickass)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by beerbongskickass &raquo;</TD></TR><TR><TD CLASS="quote">Turbo timers are for pansy's and fairy's...</TD></TR></TABLE>
**** up your ugly
as for the turbo timer check the HKS website maybe they have the instruction manuals like the greddy site
Old Jan 26, 2006 | 11:54 AM
Default Re: Turbo Timer install help 99-00 Si (sicones)
That's Farva from Supoer Troopers you dumbass...
To answer the question, just sit your *** in your car for a minute or two after you have been boosting... it's not that difficult.
Old Jan 26, 2006 | 12:06 PM
jeffk182's Avatar
Well I already have the turbo timer so might as well use it. I just need to know where the brown wire go's. Any help will be great.
Old Jan 26, 2006 | 12:36 PM
siblues's Avatar
Default Re: (jeffk182)
I know on the greddy units one of the wires is for a tach signal and it isnt used but I dont know on the hks ?I will see if I can find you a wiring diagram
Old Jan 26, 2006 | 12:38 PM
siblues's Avatar
There you go
http://www.hksusa.com/faq/?ID=1647
Old Jan 26, 2006 | 01:12 PM
jeffk182's Avatar
sweeeeet! Thanks man!
Old Jan 26, 2006 | 01:16 PM
jeffk182's Avatar
Figured it all out..the brown wire was for the RPM signal if I want to use auto timing..but I have no need for that. Thanks.
Old Jan 26, 2006 | 01:52 PM
siblues's Avatar
I figured it was for a tach signal but i wasnt sure well it all worked out for the best
bigislandc2
Dec 9, 2006 07:58 PM
MattGSR
May 26, 2004 08:20 PM
ebp 99 si
Sep 23, 2003 07:29 PM
Hybrid
Mar 19, 2002 12:50 PM
