turbo timer install
Old Sep 16, 2006 | 12:33 PM
99delsol's Avatar
Default turbo timer install
ok i just finished installing my blitz turbo timer,but the line and t connectors are hella thin,thinner than my vac. lines ,so what do i do to make it work,and also my intake manifold vacum line already have t connectors on them so do i make another one for the turbo timer.pics and diagrams would really help.please reply asap
Old Sep 17, 2006 | 01:14 AM
SiRay6's Avatar
Default Re: turbo timer install (99delsol)
if the vacuum lines that come with your turbo timer are too thin...then go to a autoparts store and find adapters that let you connect the thin lines to a plastic adapter that has a thicker hole on the other side so you can connect to your larger vacuum lines.
do you get it? basically they make plastic adapters where 1 side is like 1/8" diameter and the other side is like 1/4" diameter (just for example). So you can connect a smaller size diameter to the adapter and then on the other side of the adapter is a bigger size diameter.
Theres a few vacuum lines you can tap off of...but i wouldn't recommend tapping 2 things off 1 line except for the brake booster line...for instance the fuel pressure regulator is one source....there are other sources near/around the intake manifold (most of them are vacuum...but make sure you know)....or you can tap a few off the big fat Brake booster line. That hose is like 1/4"-1/2" thick?
If you'd like pictures...ask.
-Ray
Lewy. Dee Ayy
May 15, 2012 06:03 PM
BigZeke5
Oct 16, 2008 06:20 AM
turbotime
Jul 26, 2006 10:30 AM
Poop111444
Apr 13, 2003 06:56 PM
