turbo timer
Old Jan 22, 2004 | 02:15 PM
jaydm98's Avatar
Default turbo timer
Hey guys i just installed a greddy turbo timer. I was wondering, i have the timer set at 3 mins, the temperature goes up ( starts to overheat ), it isnt cooling down, but when i have the keys in the ignition and leave it on for three minutes. it doesnt overheat, i noticed that the fan does not come on when the timer counts down, obviously the keys are not in the ignition. and when the keys are in the ignition the fan comes on. My question is, is this normal? do the keys have to be in the ignition for the cooling fan to come on?
Old Jan 22, 2004 | 02:18 PM
Mase's Avatar
Default Re: turbo timer (slopokb16crx)
your accessories are turning off when u take the key out (meaning the fans will not operate).
Old Jan 22, 2004 | 02:22 PM
jaydm98's Avatar
Default Re: turbo timer (Mase)
So this is normal then right?
Old Jan 22, 2004 | 04:39 PM
jaydm98's Avatar
up
Old Jan 22, 2004 | 04:45 PM
JrCRXHF's Avatar
i don't think so i don't know how the greddy works but my blitz hooks up to the acc. so like my radio and everything works fine untill it counts down.
Old Jan 22, 2004 | 04:46 PM
rtype11's Avatar
you dont need it set for 3minutes, short distances max 30seconds just allow the the turbo to spool down a bit. your fan should still come on if car is overheating even if key is removed, does your fan come on at all? go through normal diagnoses for fan, fuses, relays etc..
Old Jan 22, 2004 | 05:31 PM
jaydm98's Avatar
Default Re: turbo timer (rtype11)
The fan comes on normally with the key is in the ignition. it just doesnt when the keys isnt in the ignition and the turbo timer is counting down. Mase is right,accessories isnt on,so the fan wont come on.
Old Jan 22, 2004 | 05:36 PM
rtype11's Avatar
I dont know what I did different with mine but I didnt wire in any of the safety/security features like E-brake etc.., and I have all accesories functioning during countdown.
Old Jan 22, 2004 | 05:40 PM
jaydm98's Avatar
i dunno why mine arent...mase said that his did the same thing.i have everything hooked up right.
Old Jan 22, 2004 | 05:42 PM
rtype11's Avatar
Ill take a look at the greddy site to see if any of the wires I didnt use interfere with accessories.
Only found the instructions for the greddy FATT, I have the older one whatever its called, I know mine was not wired the same, I had a whole extra harness with voilet and grey and another I didnt use. sorry.
FBP Si 2000
Apr 12, 2023 11:00 PM
91b18a1ls
Oct 15, 2011 04:24 PM
SpoolD16
Sep 14, 2009 04:11 PM
afmoose7
Apr 18, 2006 09:47 PM
B18EG6
Jul 15, 2005 11:03 AM
