Turbo suggestions for B16A3?
What is your power goal?
What is your budget?
What are you planning to use the car for?
Is the engine built? If so, what's the compression ratio and bore?
What fuel are you going to tune on?
Setup in general?
Setup in general?
What is your power goal? 250-350 WHP would be ideal
What is your budget? 4k-5k
What are you planning to use the car for? daily driver, not planning to go more than 8 psi
Is the engine built? If so, what's the compression ratio and bore? negative, at the moment engine is stock a side from headers and cold air intake
What fuel are you going to tune on? 93
Setup in general? looking for suggestions for one, never worked with turbo mostly NAs.
your best bet since you have a decent budget is to look into the Peakboost kit....also, dont worry about PSI so much, its power that kills the engine not the pressure....
Once you're not a trial member, go to http://www.hondamarketplace.com/zeroforum/49 and see what they have available in your price range
and as always, keep us updated and be sure to ask any questions you have no matter how dumb you think they may be....we're here to help (or at least i am
DumpdEJ6
Nov 28, 2016 08:16 AM
2LiterTurboSeR
Jul 11, 2009 08:36 AM
Starscream
Honda Motorcycles
10
Feb 14, 2007 05:20 AM
