turbo smoke?!?!?!please help
Old Nov 28, 2007 | 06:55 PM
skUnK2jdm's Avatar
Default turbo smoke?!?!?!please help
Iam purschasing a 92 hatch with a b16 on boost, but the problem is the the car smokes! it smokes all the time a white/black smoke. He said that is the turbo burning oil its some shitty ebay turbo! the car has alot of power and is semi built. The car was running for about 20min at idle and didnt even come close to overheating!
I will be purchasing this car tommorow what should i check for b4 doing this?
Iam planning to change the turbo anyways
Thanks for the help guys!!
Modified by skUnK2jdm at 8:36 PM 11/28/2007
Old Nov 28, 2007 | 07:07 PM
skUnK2jdm's Avatar
Default Re: turbo smoke?!?!?!please help (skUnK2jdm)
oh its on 8 lbs!!
Old Nov 28, 2007 | 07:32 PM
skUnK2jdm's Avatar
Old Nov 28, 2007 | 07:39 PM
bluedragon's Avatar
hey also check to make sure he doesnt have a coolent leek or maybe a bad piston ring that happen to one of my friends they had a pritty bad seal leak and he was burning and loosing oil and his pistons got fried.
Old Nov 28, 2007 | 07:42 PM
skUnK2jdm's Avatar
Default Re: turbo smoke?!?!?!please help (bluedragon)
how should i check this??
Old Nov 28, 2007 | 07:45 PM
bluedragon's Avatar
well you can take a comprssion tester with you and check the compression in all 4cylinders if there all of that means you have a leek or somthing is off now checking for coolant thats a little differnt I would say if the oil smells like coolant or looks like a heavy or dark green color that means he has coolant leeking into the engine
Old Nov 28, 2007 | 07:47 PM
ke98248's Avatar
I wouldn't buy a project car that doesn't work right. If he bought a cheap-*** ebay turbo, who knows what else he skimped on the car.
Old Nov 28, 2007 | 07:50 PM
skUnK2jdm's Avatar
Default Re: turbo smoke?!?!?!please help (ke98248)
ok what should comp. be at? b16a with 9:7 cp pistons
Old Nov 28, 2007 | 07:56 PM
turbodano's Avatar
it sounds like it the turbo take the intercooler pipe off and see if there is oil in it. 300 repair and you are back on the road.
bluedragon's Avatar
well that is a tuff question but I will just say this if all 4 are about the same there good inf one or more has different numbers there somthing bad in that cylinder
Old Nov 28, 2007 | 08:03 PM
Peter Brady onlyonweekndz's Avatar
did u boost the car/redline when u test drove it and didn't run hot? do the comp test and make sure the #'s are even or at the most within 20 psi of each other..not sure what its supposed to be at..how much are u getting the car for?
Old Nov 28, 2007 | 08:07 PM
skUnK2jdm's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Peter Brady onlyonweekndz &raquo;</TD></TR><TR><TD CLASS="quote">did u boost the car/redline when u test drove it and didn't run hot? do the comp test and make sure the #'s are even or at the most within 20 psi of each other..not sure what its supposed to be at..how much are u getting the car for?</TD></TR></TABLE>
well iam trading it for a eg hatch with a stock b16a with a/c clean *** hell i was asking 4500$ he has a 94 eg b16a boost a couple other items str8 trade!!
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by bluedragon &raquo;</TD></TR><TR><TD CLASS="quote">well that is a tuff question but I will just say this if all 4 are about the same there good inf one or more has different numbers there somthing bad in that cylinder</TD></TR></TABLE>
ok will check this out!!
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by turbodano &raquo;</TD></TR><TR><TD CLASS="quote">it sounds like it the turbo take the intercooler pipe off and see if there is oil in it. 300 repair and you are back on the road. </TD></TR></TABLE>
ok i will check this out if theres oil in there then it is the turbo thats bad!! ??
Old Nov 28, 2007 | 08:32 PM
skUnK2jdm's Avatar
Old Nov 28, 2007 | 08:52 PM
skUnK2jdm's Avatar
any1 else
Old Nov 28, 2007 | 09:13 PM
skUnK2jdm's Avatar
is there anything else i should check?
Old Nov 28, 2007 | 09:24 PM
skUnK2jdm's Avatar
HELP PLEASE!!
Old Nov 28, 2007 | 10:04 PM
skUnK2jdm's Avatar
Hmmmmm
Old Nov 29, 2007 | 05:00 AM
skUnK2jdm's Avatar
Old Nov 29, 2007 | 08:05 AM
skUnK2jdm's Avatar
i will be looking at car today at 5pm
Old Nov 29, 2007 | 08:11 AM
turbodano's Avatar
save yourself some time check the turbo in and out play and for oil in the pipes first. It is the quickest thing to do. It is also the most likley problem you have.
Old Nov 29, 2007 | 08:16 AM
skUnK2jdm's Avatar
Default Re: turbo smoke?!?!?!please help (turbodano)
ok so if theres oil in the ic pipes then thats the problem? that means thats its burning the oil!!
Old Nov 29, 2007 | 08:52 AM
turbodano's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by skUnK2jdm &raquo;</TD></TR><TR><TD CLASS="quote">ok so if theres oil in the ic pipes then thats the problem? that means thats its burning the oil!!</TD></TR></TABLE>
It means the turbo is failing and oil from inside the turbo is buring in the exhaust. It is a common problem when turbos are on the way out.
Old Nov 29, 2007 | 09:19 AM
skUnK2jdm's Avatar
ok cool!! iam deff gonna check that first!
Old Nov 29, 2007 | 12:01 PM
skUnK2jdm's Avatar
Old Nov 29, 2007 | 03:19 PM
bluedragon's Avatar
so whats the word little buddy what wa sthe prob did you get it
