which turbo should i pick
Old Jul 10, 2004 | 04:28 PM
Mr. JDM-GSR's Avatar
Default which turbo should i pick
im new to the whole turbo seen so i wanted to know what would be the best trim and turbine and also what is a wet bearing housing.This is for a fully built gsr motor. i want to go with the t3/t4 setup and these are the types that i found:
TURBO SPECS
WET BEARING HOUSING
First Turbo Specs:
COMPRESSOR SPECS:
flow: 50 lbs/min 640cfm
.60 A/R HOUSING
57 TRIM WHEEL
TURBINE SPECS:
.48 A/R HOUSING
STAGE 3 WHEEL
standard with 270 degree thrust bearing
Turbo # 2:
COMPRESSOR SPECS:
flow: 46lbs/min 588cfm
50 TRIM WHEEL
TURBINE SPECS:
.48 A/R HOUSING
STAGE 3 WHEEL
oil lubricated centersection.
# 3rd Turbo
COMPRESSOR SPECS:
flow: 46 lbs/min 588cfm
50 TRIM WHEEL
TURBINE SPECS:
.63 A/R HOUSING
STAGE 3 WHEEL
4th Turbo
COMPRESSOR SPECS:
.60 A/R HOUSING
57 TRIM WHEEL
TURBINE SPECS:
.63 A/R HOUSING
STAGE 3 WHEEL
5th Turbo
COMPRESSOR SPECS:
flow: 53 lbs/min 678cfm
.60 A/R HOUSING
60 TRIM WHEEL
TURBINE SPECS:
.63 A/R HOUSING
STAGE 3 WHEEL
6th Turbo
COMPRESSOR SPECS:
.60 A/R HOUSING
60 TRIM WHEEL
TURBINE SPECS:
.82 A/R HOUSING
STAGE 3 WHEEL
Old Jul 10, 2004 | 04:39 PM
tygsr's Avatar
Default Re: which turbo should i pick (Mr. JDM-GSR)
It all depends on what kind of power you want to make. The .60 trim is a bad *** turbo...
Old Jul 10, 2004 | 04:50 PM
Default Re: which turbo should i pick (tygsr)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tygsr &raquo;</TD></TR><TR><TD CLASS="quote">
It all depends on what kind of power you want to make. The .60 trim is a bad *** turbo...</TD></TR></TABLE>
im looking for some good power in the range of up to 350 whp
i want to put down some real trouble for those modified mustangs
Old Jul 10, 2004 | 05:43 PM
tygsr's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Mr. JDM-GSR &raquo;</TD></TR><TR><TD CLASS="quote">
i want to put down some real trouble for those modified mustangs </TD></TR></TABLE>
That turbo should make that..depending on how much psi and if your motor is built, etc
Old Jul 11, 2004 | 11:43 AM
Does anyone know what a wet bearing is?
Hulkmanj99
Oct 14, 2004 12:49 PM
ATS*Mark
May 23, 2004 08:57 AM
ArchAngel Sabastian
Jan 4, 2004 10:46 PM
d98clturbo
Jul 29, 2003 06:22 PM
Quik Chris
Nov 3, 2002 09:29 PM
