turbo return question
Old Jul 12, 2011 | 10:57 PM
4tika4's Avatar
Default turbo return question
so i got my turbo installed, it turns out my oil line was kinda kinked so it blew the seals. we fixed the line and the turbo still leaked out of one of the bolts on it. So i got a new turbo. i was wondering if the hole on the bung was too small, how big should it be? i tried putting the back end of a sharpie marker through it to check the size and it was a little too small.
also, would too much oil in the engine play a factor in oil backup? how much oil is in the pan when the car is running?
Old Jul 13, 2011 | 04:44 AM
carnot's Avatar
Default Re: turbo return question
Are you referring to the oil drain line size from the turbo to the pan? I am using a -10AN for the return. How far down from the oil pan flange is the return port?
Old Jul 14, 2011 | 04:13 AM
MR.johnson's Avatar
Should be a -10 some say -8. The center section should not be clocked more than 30degrees. Is it a ball bearing turbo?
Old Jul 14, 2011 | 06:03 AM
TheShodan's Avatar
Moderator
Originally Posted by MR.johnson
Should be a -10 some say -8. The center section should not be clocked more than 20degrees. Is it a ball bearing turbo?
Fixed.
BoostThisMS
Jan 25, 2013 08:46 PM
sheepey
Apr 22, 2010 09:33 AM
z6
Jun 3, 2004 11:03 AM
dunkd
Mar 8, 2004 09:07 PM
reignofchaos
Jul 31, 2003 07:48 PM
