Turbo rebuild
Old Jan 1, 2009 | 09:49 PM
Christopherian1982's Avatar
Post Turbo rebuild
Engine:
B16
Greddy turbo kit
I Blew my rings and I wanna know what steps to take if I wanted to upgrade a couple of things since rings are being in place. I wanna know what to get and that I have a money budget of $750-1000...
Old Jan 1, 2009 | 09:59 PM
90sedan's Avatar
Default Re: Turbo rebuild
So what exactly is the question?
Old Jan 1, 2009 | 10:15 PM
cockerkid008's Avatar
uh get rings..
and please write in english
Old Jan 1, 2009 | 10:17 PM
93ls10.0's Avatar
wow just wow
Old Jan 2, 2009 | 07:08 AM
redlinetuning's Avatar
First off, $750-$1000 won't get you much.
When replacing rings, you'll need a fresh hone. Depending where you go, assembly will cost anywhere from $300-$500 unless you know someone who will reassemble your short block for you. Your engine builder should be able to tell you if your cylinder walls are warped, or any other damage besides the rings.
While you're at it, check the main/rod bearings and replace if needed. I recommend checking the water pump and oil pump as well as the front main seal, gaskets etc... Unfortunately, by the time you're all done, you'll realize you've spent more than what you intended. However, water and oil pump replacement is relatively easy if you're competent.
FlashfmDB8
Aug 6, 2013 05:40 AM
dgie
12
Jul 6, 2008 06:41 AM
ej1252
Jul 2, 2008 09:10 PM
djnikko
Nov 9, 2005 03:24 AM
Captain_Kicker
Aug 5, 2003 06:54 PM
