Turbo Problems
Old Nov 19, 2002 | 03:45 PM
T62-1GSR's Avatar
Default Turbo Problems
I have a 96 civic with a GSR motor and a custom turbo kit running 7lbs. I have a skunk 2 jumper harness to convert my car to obd1 and a stock obd1 p72 ecu. My car is throwing a code 43 ( which is a fuel system supply code). My air/fuel guage stays on lean when the car starts and when it idles. When i give the car gas it goes to stoich and stays there. I have replaced the o2 sensor 3 times, replaced the fuel pump to a 255, replaced the fuel lines, injectors, fuel filter, taken off the fuel rail and cleaned it, and new pressure regulator. My car still throws the same code. The car will only throw the code after boost and driving normal. The car is running really rich becuase gas mileage is terrible. I do have a vortech 12:1 fmu in the car. Is it a voltage problem???? At this point im baffled. Any info would help out.
boosted civi
12
Apr 29, 2010 07:19 AM
lamsv
Nov 23, 2005 10:13 AM
95hatchfire
Jan 12, 2005 10:52 AM
wrXtian
Dec 20, 2002 11:11 AM
T62-1GSR
Nov 19, 2002 11:10 PM
