turbo prelude problems...help
Old Feb 28, 2006 | 09:55 PM
efiv5lude's Avatar
Default turbo prelude problems...help
I just put a T3 turbo(6 lbs) on 97 prelude and it runs like crap (sputters when i give it gas and doesnt pull at all). I put on dsm 450 injectors with inline 10 ohm resistors, and im running it with a field sfc-vtec contoller. i have a FMU, but dont know if i should use it with the sfc.
Old Feb 28, 2006 | 10:04 PM
efiv5lude's Avatar
Default Re: turbo prelude problems...help (efiv5lude)
also, my boost gauge never sees boost, only vac. wastegate is set at 6.
Old Feb 28, 2006 | 10:14 PM
Fitti's Avatar
STOP!
Find your nearest tuner and tune the car.
Pay the $$$ TO TUNE IT or PAY THE $$$ for a new engine
$$$ to Tune < The $$$ for a motor
Old Feb 28, 2006 | 10:25 PM
Cyberdx16's Avatar
Default Re: (Fitti)
2nd!
Old Mar 1, 2006 | 01:09 AM
flip1199's Avatar
Default Re: (Cyberdx16)
check all couplers/vacuum lines and get the damn thing tuned.
Old Mar 1, 2006 | 04:22 AM
bubs's Avatar
Edit: Nevermind
Old Mar 1, 2006 | 06:53 AM
efiv5lude's Avatar
Default Re: (Fitti)
Do you know any around central maryland? also why isnt my boost gauge working?
Old Mar 2, 2006 | 08:18 AM
Fitti's Avatar
I'm in Cali so we have tuners every where. But hit up SN Turbo-Charged on here. I think he is actually in your local area and can get you hooked up.
Old Mar 2, 2006 | 08:34 AM
Turbo-charged's Avatar
Default Re: (Fitti)
i'll be honest....if you want me to tune the car i will want to do it correctly. hondata, a honda resistor box, and a walbro fuel pump.
you are fighting a never ending battle trying to use your set up right now. feel free to contact me if that is a route you would like to take. 301 638 3000
Old Mar 2, 2006 | 09:38 AM
Pullig's Avatar
Default Re: (Turbo-charged)
to use that setup pull off the FMU use that VAFC and take away -35 accross then tune the AFRs . Keep the 450s in.
Old Mar 2, 2006 | 10:03 AM
xrunner86x's Avatar
Default Re: (efiv5lude)
I have personal experience with Tempest Racing in Waldorf and JE Import Performance in Baltimore. Tempest has a Dynojet and JE has a Dynapak. I cant entirely recommend JE for everything but for tuning they are good. Inline Pro in NoVa might be worth the drive.
Old Mar 2, 2006 | 06:14 PM
efiv5lude's Avatar
Default Re: (Pullig)
i talked to a tuner and he told me to take the 450s off and have it run the stock injectors with the fmu. runs fine. boost gauge still doesnt read, bov doesnt blow off. i dont know why, possibly a leak in the vacuum lines?
ragethemachine86
Jul 22, 2006 01:37 AM
ragethemachine86
Jul 21, 2006 06:21 PM
bella_bluelude
Aug 3, 2005 08:15 PM
oxhernandez
Apr 15, 2005 09:42 PM
luderone
May 22, 2003 04:52 PM
