Turbo in- No boost
Old Aug 7, 2004 | 10:18 AM
MooreBoost's Avatar
Default Turbo in- No boost
Everything is finally squared away with my turbo. However I took it out for a spin and I saw no boost. I switched the wastegates and that did not help. My boost gauge says no boost, as does my VAFC, and I hear nothing from my BOV, so theres definitely no boost. I am using the nipple on the 14b eblow on the compressor side for the vacuum for my wastegate. I can hear the turbo spool (I think, first turbo car), and the car runs fine other than that. It feels just like it did before I bolted on the turbo, minus any boost. The turbo I bolted on wasn't in great shape, there were alot of cracks around the wastegate and in that area, but I bought the turbo from a good friend who had it on his 4g63, and it pulled hard. Heres my setup if its any help-
DOHC ZC
14b w/ stock wastegate
FMIC
DSM 450s
AFC Hack
HF Mani
Adapter Plate
Any ideas?
Old Aug 7, 2004 | 10:22 AM
MooreBoost's Avatar
Default Re: Turbo in- No boost (tegunderpressure)
And it runs fine to redline, it doesnt bog when it "should" be boosting.
Old Aug 7, 2004 | 10:25 AM
twkdCD595's Avatar
did you double check your charge piping and whatnot for leaks?
also are the turbine blades moving/ spinning freely?
Old Aug 7, 2004 | 11:09 AM
MooreBoost's Avatar
Default Re: Turbo in- No boost (twkdCD595)
The charge piping looks good, if there is a leak, its not this big. Ill have to go look at the blades, but I imagine they are. Any other ideas?
Old Aug 7, 2004 | 11:11 AM
beepy's Avatar
Exhaust leak at the manifold, leaking charge pipes, wastegate not fully seated.
Old Aug 7, 2004 | 01:37 PM
MooreBoost's Avatar
Default Re: Turbo in- No boost (beepy)
Ok, I found a large exhaust leak, and fixed it, now there is very slight boost, but not much. My AFC read a fraction of a pound. However, when I fixed the exhaust leak, I switched back to the old wastegate (its a lower PSI), and Im not sure that wastegate works. I will put back the stock wastegate tommorrow. I cannot feel any more leaks, and the charge pipes are all clamped up. The Precharger filter couldnt have anything to do with it, could it? I have it right over the turbo inlet, so that only leaves me with about a 1.75 inch circle of filtering area, and this is a very fine material.
Old Aug 7, 2004 | 09:06 PM
MooreBoost's Avatar
Bump.
Old Aug 8, 2004 | 11:14 AM
MooreBoost's Avatar
I found another exhaust leak, but I cant get rid of it. Its inbetween the turbo and the piece that converges the exhaust and WG exhaust (dont know what thats called). I tried torquing down the two bolts the leak is inbetween, but that didnt help. I even used a breaker bar to get it as tight as possible, I actually broke an extender clean in half while torquing it. And ideas?
97boostedteggy
Apr 18, 2016 11:39 PM
allmotor_dm
Jan 24, 2006 06:07 PM
MiMiK
Dec 10, 2005 06:21 PM
RFd15bhatch
May 24, 2005 12:27 PM
SOHC_MShue
Jun 15, 2004 09:52 PM
