Turbo mini me question??
Old Sep 20, 2003 | 06:48 PM
VTEC_warrior94's Avatar
Default Turbo mini me question??
IS it true that when you turbo the car the v-tec does not work?? people are telling me tehre is no point to do a mini me swap and turbo, also is it worth it to do the mini me swap and turbo, or just turbo the stock d15 fronm a 1992 civic, and last is it true that the mini me turbo set up will only last 2000 miles before it blows?? thanks!
Old Sep 20, 2003 | 07:04 PM
4ceFedTeg's Avatar
Default Re: Turbo mini me question?? (VTEC_warrior94)
LIES !! You can turbo anything as long as you tune it right and use common sense (ex: a stock engine cannot handle 35psi) as with the vtec problem, I THINK the rumor is that when vtec kicks in, you lose a little bit of boost, which makes sense. But if that is the problem, a dual stage boost controller will fix that.
south_crx
Nov 25, 2006 05:31 AM
ekzrated
Feb 16, 2005 07:28 AM
Chief Brody
Sep 10, 2003 11:01 PM
JSMC
Jul 22, 2003 09:37 PM
builtB20turbo
Oct 16, 2002 05:32 PM
