Turbo LS-V missing at 8-9k?
Old Apr 21, 2013 | 05:01 PM
TeggieeTuner's Avatar
Default Turbo LS-V missing at 8-9k?
I have a brand new set of ngk blue plug wires,new ngk bkr7e plugs gapped to .18 and a new oem cap ,rotor, and tec coil....
On race gas on the dyno i was running an msd blaster 2 coil and it was breaking up at high rpms.. So i took it off when I got home and put the oem one back in and changed the map back to pump with 93 octane in it and it was fine at first... raced a couple people and it started cutting out shortly after...
It runs fine at lower rpms and even the transition into boost but past 8k going on 9k it starts cutting out... My af/r's dip into the mid to low 10's though...
Im making 400ish on pump so surely the stock ignition is not maxed out yet.
Im going to call Mase tomorrow and see if he can throw it back on the dyno and see... I just figured I would try and get a head start here.
Old Apr 21, 2013 | 06:28 PM
Default Re: Turbo LS-V missing at 8-9k?
My setup is as follows:
Block:
84.5mm Benson sleeved B18a1
Benson micro-polished crank
Pauter Rods
CP 9:1 pistons
Head:
Port mached Gsr head
Skunk2 Pro 1 cams
Skunk2 Pro springs/retainers
fresh resurface, valve stem seals
Edelbrock Victor xintake
Hondata IM gasket
Omni Power 70mm Throttle body
ARP Head Studs
T1 race development catch can kit (6 line kit) Black braided lines
AEM Cam gears
King motorsports T3 Topmount + downpipe
Precision Sc61 .63a/r ,.70 ported "s" Compressor
Precision 46mm wastegate
Tial 50mm BOV
ID 1000cc injectors
Walbro 400lph pump
Aem Fuel rail
Fuel Lab FPR ( not installed)
Fuel lab inline fuel filter
Ignition:
Oem dizzy,plug wires ect..
The msd I had was junk
Old Apr 21, 2013 | 06:49 PM
Turbo-LS's Avatar
Sound like an Ignitor failing. Get a new one or ditch it and upgrade your ignition. I highly recomend upgrading the ignition system. It can be done in expensively and be reliable. Summit digital CDI box with crane LC-92 coil and an Ignitor bypass box
Old Apr 22, 2013 | 03:03 AM
236.67 shipped for the CDI box and coil from summit. How much for the bypass?
Old Apr 22, 2013 | 04:44 AM
Turbo-LS's Avatar
70 shipped
pettyboy69
Jul 16, 2018 04:25 AM
jdm_h22
Nov 11, 2015 10:45 AM
Baddawg1991
17
Nov 4, 2014 06:59 PM
victor.ek4
189
Dec 4, 2009 02:36 PM
cnydelSolHybrid
Jun 25, 2003 02:53 PM
