TURBO ls throwin trouble code 43, HELP!!
Old Aug 29, 2006 | 07:29 PM
teg racer 877's Avatar
Default TURBO ls throwin trouble code 43, HELP!!
Ok my obd1 ls has been turbo for about 4000mi, it just started throwing code 43, (fuel supply), and when im crusing 60-90mph it will feel like it cuts out/ feels weird, any advice on whats going wrong? here is the fuel related setup.
s200b afr is on the lean side and uneven, need retune (related?)
rc 550cc
walbro 255
247whp
208ft lbs.
Old Aug 30, 2006 | 05:32 AM
Default Re: TURBO ls throwin trouble code 43, HELP!! (teg racer 877)
bump, anyone??
Old Aug 30, 2006 | 06:15 AM
DaveF's Avatar
try a new 02 sensor. yours could be old and foul'd.....
how does the a/f look @ idle and @ lower engine speeds ?
Old Aug 30, 2006 | 07:05 AM
Jay_Sensing's Avatar
Everytime I have gotten that code it has been due to a bad o2 sensor. I am sure it could be a few other things as well but that is the first place I would look.
Old Aug 30, 2006 | 08:32 AM
Finland's Avatar
yep definitely o2 sensor.
Old Aug 30, 2006 | 01:17 PM
Default Re: (Mr. Helsinki)
ok thanks guys, I talked to my instructors at school (all ase certified master techs) and they said pretty much the same thing, my afrs are lean at low rpm so it made my o2 sensor go bad which is making it run weird at low rpm right?
Old Aug 31, 2006 | 04:11 AM
Finland's Avatar
Default Re: (teg racer 877)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by teg racer 877 &raquo;</TD></TR><TR><TD CLASS="quote">ok thanks guys, I talked to my instructors at school (all ase certified master techs) and they said pretty much the same thing, my afrs are lean at low rpm so it made my o2 sensor go bad which is making it run weird at low rpm right?</TD></TR></TABLE>
running it lean should keep the o2 sensor clean, usually when the car is pig rich is when the o2 sensor gets contaminated.
Old Aug 31, 2006 | 04:49 AM
blackeg's Avatar
disable that o2 sensor. ive never run an o2. just tune your maps accordingly and you will get just as good if not better mpg
Old Sep 1, 2006 | 10:08 PM
Default Re: (blackeg)
but doesnt the 02 sensor help with keeping correct afr's when temp and humidity are changing? I thought the 02 sensor was important, no?
Old Sep 1, 2006 | 10:14 PM
If I dident need to be running an o2 sensor in the first place than why did my car all of a sudden start acting funny like its super lean at low/crusing rpm (3000-4000rpm)?
I thought I had this figured out but now im more confused than when I started
Old Sep 2, 2006 | 05:15 AM
Finland's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by teg racer 877 &raquo;</TD></TR><TR><TD CLASS="quote">If I dident need to be running an o2 sensor in the first place than why did my car all of a sudden start acting funny like its super lean at low/crusing rpm (3000-4000rpm)?
I thought I had this figured out but now im more confused than when I started </TD></TR></TABLE>
some people prefer to run their cars in open loop..which is fine if the weather never changes..
I run mine in closed loop/open loop like honda intended from the factory..I live in Michigan where it could be 100 degrees 100% humidity one day and 65 degrees the next day..open loop would be bad news for me.
I'd suggest just replacing the o2 sensor and then make a tuning decision after that.
Old Sep 2, 2006 | 05:18 AM
blackeg's Avatar
your program should have correction factors built into it( ie iat's). that should help you stay the same a/f if the weather changes
Old Sep 2, 2006 | 11:19 AM
yea my s200 has correction but how will the ecu read changes with no o2 sensor?
well my tuner says open loop is not a good idea so Im gonna keep the 02.
This is what im gonna do, tell me if its a good idea:
1 get new 02
2 get b&m fpr
3 get retuned a little richer (mostly at low rpm) and more even.
Old Sep 2, 2006 | 11:40 AM
mtber's Avatar
Disable o2 feedback & save your self tons of headaches.
Old Sep 2, 2006 | 03:05 PM
nickromeo's Avatar
Default Re: (mtber)
B&M FPR's arent the most reliable things
Elbowpunk
Feb 3, 2006 06:50 PM
EgxHaTcHxGsR
Sep 10, 2005 10:08 PM
1sikhatch
Apr 19, 2005 04:51 AM
s14hybrid
Nov 24, 2004 05:16 AM
0bd1_Kanobe
Apr 18, 2004 02:06 PM
